 Post subject: Water damaged hard drive - need quote
PostPosted: February 12th, 2011, 21:17
I have a drive with verified water/smoke damage (there is water still inside the drive). What price range are we looking at for a recovery and what are the success rates here. Looking for a US based referral. The drive is a 160 GB Samsung.
 Post subject: Re: Water damaged hard drive - need quote
PostPosted: February 12th, 2011, 22:15
In order to give you rough estimate you should provide as many details as possible....
www.datarecoveryne.com
PostPosted: February 14th, 2011, 23:39
Drive is a 160 GB Samsung - HD160JJ/P. Firmware is ZM100-34.
PostPosted: February 18th, 2011, 5:45
Further information will be required to be able to give an accurate quote.
How did the drive get smoke/water damage?
Is the water salt water or clean water?
How long has the drive been in this condition?
PostPosted: February 20th, 2011, 4:19
if its salt water the platters will be eaten away by now
if its still water then the recovery can be done.
allso depends on how long you have had the drive sitting
Users browsing this forum: No registered users and 35 guests
