Forum rules
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Larger Drives > 1TB
PostPosted: February 14th, 2011, 12:25
Okay, I'm sure that we are not the only lab finding ourselves wasting a lot of time with really large drives and having our quotes declined or finding that we are spending a lot longer on the project than expected. I'm curious to know what other labs are doing.
1. If the drive detects, are you doing a full clone before you check the file system to see if the data is accessible?
2. Do you charge more just because of the drive's size?
3. How do you deal with short term archiving of your client's data?
Using DDI, it can take 11 hours to clone a healthy 2TB drive. If the client's file system is corrupt, it could take a couple of days to do a full scan of the drive.
4. Do you just guess and quote in advance?
5. Do you take the time to recover the data, then quote?
 Post subject: Re: Larger Drives > 1TB
PostPosted: February 14th, 2011, 18:45
If it's detected and I can see the files with R-Studio for instance, no clone. I get the files the client wanted right away
Normally No
I save them into my PC's and external drive until the job is accepted or not
First, I have to check if I really have the files, even if it takes 2 days..
Yes
ACELab partner
PostPosted: February 15th, 2011, 4:02
1.no way going to the data straight away one chance recovery before drive goes bye bye
2.normally no set rate for any drives
3.save them onto external drives and allso burn onto dvdrs and then once the job is accepted its all done
4.first do the recovery then check that the files are the ones i need then test them out first
5.yes all the time can take up to two days or longer
PostPosted: February 15th, 2011, 10:29
Isn't that risky and hard on the drive?
Normally No
So, a project that takes 1 day is the same price as one that takes 4 days?
How long do you store the data?
We check the files before we officially call the project recoverable. But, this happens after they accept the quote.
Yes
So, you spend the money and time to do a $1000 recovery before you find out that it is only worth $50 to the client? Our goal is to quote the client ASAP, the sooner they are quoted, the more likely that they are to accept. The longer you wait, the more time they have to find their data in other places and decide that their data isn't as important to them as it was when they sent it in.
PostPosted: February 15th, 2011, 10:35
This is a wise decision and why I find that DDI is invaluable to us.
But, would you charge more because it is going to take you longer to recover the data?
You save the clones on external drives and DVDs or just the recovered data? We store the recovered data for the two week holding period, but our main priority is to hold the clone for that time frame. It is more likely that we have to go back to the clone and try to recover a file, using different methods, rather than go back to the recovered data, which the client already has.
Again, this makes no sense to me. You would spend $250 on a parts drive, get it in, change the heads, spends several days or weeks mirroring the drive, recover the data, test the data, then quote the client? Man it must really suck when you get the projects turned down...unless you are charging $100 for everything...either way, aren't you losing money doing it that way?
PostPosted: February 15th, 2011, 16:01
Simplest way is to analyse the drive quickly, determine what fault is and quote accordingly. We provide a scale of recoverability from Very Low to Very High, based on experience. Spending days and days determining if a drive is recoverable is fine if this is not your sole income or if you are a small operation, but diagnosis should be quick and get the quote to your customer within hours and let them make the decision before you pour valuable time and labour and parts into it.
Data Recovery Ireland
PostPosted: February 15th, 2011, 16:03
btw.......it's ridiculous that some people are charging flat rate no matter what the capacity is. Clearly, a 2 TB HDD is going to take far longer than a 60GB HDD and if you have overheads, you gotta charge on a capacity basis..........again, assuming one is running a professional operation (by no means am I inferring you are not btw Luke.)
PostPosted: February 15th, 2011, 16:09
I don't charge a flat rate...and certainly do charge more for larger drives, most of the time. I started the discussion because we were having the discussion here amongst my staff and I was curious to see what others were doing.
It is my guess that those who are spending days doing the assessment are low price one man shows. I cannot afford to pay my staff to waste time on a project that might not be worth the time spent on it. So, our goal is to quote within a few hours of the drive arriving...no later than the next business day.
PostPosted: February 15th, 2011, 17:29
Agree with CK
PostPosted: February 15th, 2011, 18:30
It depends on the problem that the drive has. If it's only a logical problem and few files to recover, why not? If it click
Normally No
Of course, times is money. If a job takes 4 ou 5 days, it's because the drive is alot bad, right? So the price will be other too
I can save it for 2-3 weeks, at least, after the client got his files, and I don't need the space
Yes
Yeah that could happen. But when a disk cames in, we can make a quick diagnostic and tell the client right away if it's a $50 or $1000 job. If he's not interested, we don't even start
About what CK said, he's also very right, but 2TB drives, are not very usual yet. When they start to come, we can adjust then.
ACELab partner
PostPosted: February 16th, 2011, 2:50
we dont have any turn down we do recovery work for a lot of undisclosed clients
allso we spend a average of about $400 on parts
no recovery no fees to pay
we use hardware industry machine which cost A LOT OF MONEY
where no one on this forum will ever have or know what it is
PostPosted: February 16th, 2011, 5:02
I don't think you got it Craig...
When such cases came in, for instance a clicking drive, we say to client to expect a high quote, not to expect $50. If the guy says it's too much, then we don't even start.
But if we say it may cost $700-$1000, of course, the process of buying the parts, imaging whatever, starts. And we know that only if we can't get the data, there's no charge.
If you get a client willing to pay only 50-100$, for a logical error for instance, you don't do it?
ACELab partner
PostPosted: February 16th, 2011, 10:24
Last year, you were just a computer repair shop that dabbles with data recovery. Now you have a machine that nobody on this forum even knows exists and never have a quote turned down? Something is not making sense here...you are starting to sound like CSSI. What company are you working for? I'd love to stop by and say hello the next time I'm in Toronto.
PostPosted: February 16th, 2011, 10:32
I always get a good laugh from these comments.
Are you talking about the hard drive spray machine? :lol:
PostPosted: February 17th, 2011, 5:57
hard drive spray im going to sell it two for one offer $150
:mrgreen:
PostPosted: February 18th, 2011, 3:00
It depends on how much 'A LOT OF MONEY' is... :mrgreen:
PostPosted: February 18th, 2011, 4:38
Maybe the recovery industry has to change the way it operates bringing in a more realistic pricing structure. At least charge a minimum fee for evaluation of large drives which might even include the cost of imaging, which can later be deducted from the clients final bill if the recovery is accepted.
If I go to my solicitor or lawyer he will quite happily take on my case. If we win he will charge me accordingly and if we lose he will charge me just the same!
PostPosted: February 18th, 2011, 5:47
@Dick
Respect for the quote
"If I go to my solicitor or lawyer he will quite happily take on my case. If we win he will charge me accordingly and if we lose he will charge me just the same!"
PostPosted: February 18th, 2011, 5:48
Reading the same alternative forum as me :O)
PostPosted: February 19th, 2011, 10:22
CK, CK, hiiiii
