 Post subject: Momentus 5400.6 LBA 0
PostPosted: February 21st, 2011, 10:03
Hello
Can anybody tell solution for repair LBA 0
on Seagate Momentus 5400.6?
 Post subject: Re: Momentus 5400.6 LBA 0
PostPosted: February 22nd, 2011, 4:44
what to do in terminal ?
PostPosted: February 22nd, 2011, 5:08
First use m command on T level, power of/on, N1 command on level 1.
PostPosted: February 22nd, 2011, 7:40
Hi...
Before anything else I think I would carry out a head test first.
Then I would follow clayrons advice and post a log as in this thread: seagate-st9500325as-5400-t15155.html#p99337
1. disconnect pcb from heads, but keep motor connected and power on disk, turn on terminal ^Z
2. wait when motor stops and give a command to stop motor (/2 and Z)
3. press ^X
4. connect pcb and run drive by U command
5. when drive spins up
6. press ^X
7. type /T then V4
8. press ^X
9. send log to forum...
10. do not try commands like N1, m0... etc... it could destroy overlays at this moment.
PostPosted: February 22nd, 2011, 9:00
Same procedure as the 7200.11 apart from no need to isolate the PCB. The LBA=0 problem is also happening on Seagate laptop drive.
DR Research Engineer
PostPosted: February 23rd, 2011, 11:34
we had following problem
N1, or m command is not working
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.141 msecs
F3 2>U
Spin Up Complete
Elapsed Time 1.917 secs
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:00237EC5
LED:000000CC FAddr:00237EC5€
Rst 0x08M
ASCII Diag mode
F3 T>/2
F3 2>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00
00 A0 E1
opts = 00000000
RW Err = 84150180
Z
Input Command Error
F3 2>Z
Spin Down Complete
Elapsed Time 0.137 msecs
F3 2>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
LED:000000CC FAddr:00259A4D
PostPosted: February 23rd, 2011, 11:42
we have run the m command, but the problem is probably in heads
F3 T>V4
Reassigned Sectors List
Original New log log log phy phy
LBA PBA cyl hd sctr zn cyl hd sctr SFI
603F00 603F1C 34F 1 6DB 0 34F 1 6DB D750B BBM
603F01 603F1D 34F 1 6DC 0 34F 1 6DC D76F7 BBM
603F06 603F22 34F 1 6E1 0 34F 1 6E1 D80E4 BBM
603F07 603F23 34F 1 6E2 0 34F 1 6E2 D82D0 BBM
3A38602F 3A394E09 2943F 1 FC 17 29637 1 FC 113CB BBM
Alt Pending Total Alted Total
Entries Entries Entries Alts Alts
Head 0 0
Head 1 5
Head 2 0
Head 3 0
Total 0 5 5 0 0
Total Alt Removals: 0
Checksum = 1E3C
PostPosted: February 23rd, 2011, 12:42
Did you try to short the PCB on this one?
Iorana Haraharaini
PostPosted: February 24th, 2011, 4:33
"Init SMART Fail" appears if you use
F3 1>N1
BEFORE m command... I warned you.
Users browsing this forum: Google [Bot] and 327 guests
