 Post subject: 7200.11 busy problem cannot be fixed
PostPosted: January 10th, 2011, 12:54
hello.
i am having a problem with Seagate 7200.11 series.
at the atola it seems to have the usual busy problem and zero capacity problem.
when i use the terminal to fix it there is an error comes up and cannot complete the procedure.
i have attached a screenshot as well as a notepad where i copy paste the terminal dialog.
any advice would be helpful
thank you
screenshot.rar [45.25 KiB]
Downloaded 297 times
 Post subject: Re: 7200.11 busy problem cannot be fixed
PostPosted: January 10th, 2011, 15:44
What is the actual symptoms of the problem?
Some quiet clicking 11-12 times then spin down?
PostPosted: January 11th, 2011, 3:40
i noticed that ur drive is Password Locked
u need to unlock it 1st. :shock:
PostPosted: January 12th, 2011, 11:39
yes thats the problem; Some quiet clicking 11-12 times then spin down.
i tried to unlock it but its not responding
PostPosted: March 6th, 2011, 3:08
it is possible to unlock the drive through terminal commands
u need to read more about this.
also, you may consult Ann for this since she wrote it on her book for seagate.
good luck
Users browsing this forum: No registered users and 217 guests
