 Post subject: PS3 HD issues
PostPosted: March 8th, 2011, 16:26
Hi
I have a Toshiba MK1255GSX - 120Gb Hard drive that I am having problems with.
I have run various programs on the HD to check that its not damaged and it seems to be ok. There are no bad sectors etc.
You can format the harddrive to fat32 (for ps3) or NTFS etc and it dosnt show any issues.
The problem that i am having is when i install this hardrive in to the PS3 and then try to install new software on HD it gives me a hardrive error.
Also, in windows xp pro when i goto MMC i cant format the HD.
What i would like to do is completly wipe the hd clean and start again with it. ie, low level format, then fat32 format etc.
Has anyone had problems with this kind of thing before and secondly, what is the best software to use to get the hd in its orginal condition ...?
 Post subject: Re: PS3 HD issues
PostPosted: March 8th, 2011, 17:46
Tried this? I was going to type it out, but they already did, so why hassle.
http://www.ehow.com/how_5909868_fix-har ... rrupt.html
PostPosted: March 8th, 2011, 21:10
If you explained the history of that drive (what equipment it came from; was there any problem or unusual behaviour there; etc.) this might lead to you getting additional suggestions from members here.
Again, if you explain exactly what software you have run, and how the disk was attached to the system running those tests (e.g. in a USB case?), that might help others to give you suggestions.
Then you say 2 things which seem to contradict each other:
[my emphasis above]
You either can, or can't, format the disk - which is it?
If I was in your situation, I would look in the WinXP system event log, for the time when you attempt to format the disk, and look for events logged at that specific time (which you can then decode to get specific error information). However, the apparent contradiction above also needs to be resolved / explained.
PostPosted: March 9th, 2011, 1:03
ps3 fat 32 only nothing else
if the sony ps3 tools can not restore the ps3 hard drive then there is something wrong with the
firmware on your ps3
did you by anychance do a update of the firmware and did not let it finished
allso are you on about ps3 hack running software from the hard drive ????????????
PostPosted: March 9th, 2011, 7:22
Vulcan, if you read what i have wrote it does say that the hd is for a PS3.
The ps3 hd can only be formatted to fat32 for it to work on the PS3.
But, using MMC you can see the HD.
I have used other tools to format the HD to fat32 etc.
Now, the HD does show on windows xp and you can see its full capacity etc. However, the PS3 will reject this HD and say that the HD is corrupt.
The history behind this HD is that it was the orginal HD in the Sony PS3. The PS3 was working fine until one day it fell on to the floor. Since then, there has been a HD issue.
I have not come across this issue before as this is the first time i am working with a games console.
So, if there are any gamers out there who have had this problem please let me know.
PostPosted: March 9th, 2011, 8:26
I don't know which of my specific questions you think you're answering in that comment, but criticising people by claiming that they haven't read your post, isn't likely to encourage them to spend their time helping you, is it? ;) No worries, I'll just go back to playing my PS3 :)
PostPosted: March 9th, 2011, 10:03
No Vulcan i didnt mean to upset you or offend you in anyway...... sorry you feel hurt .
PostPosted: March 9th, 2011, 10:14
Falling on the ground didn't make it forget how it was formatted. Obviously there is now some physical problem with the drive. No point in trying to keep using it.
PostPosted: March 9th, 2011, 11:00
Hi
I think that the HD has some kind of issue related to it. Perhaps it was there before it fell on the ground or developed after - im not sure on this as this PS3 is not mine.
Very little advice on how to solve this matter out there .
PostPosted: March 11th, 2011, 14:35
replace the hard drive with a new one
they are cheap
then the machine will work again.
system restore
allso make sure that the connectors are connected inside the ps3
sometime they do come loose
Users browsing this forum: Google [Bot] and 8 guests
