Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 500GB (ST9500325AS) 5400rpm PCB Problem
PostPosted: March 24th, 2011, 8:33
Yesterday i plugged my HDD to a 4 pin to SATA Power Cable and the cable was burnt and the PCB was little warm. I thought the cable is burnt so i plugged it back to my laptop and it did not detect my HDD. I tried it on my PC and the drive was not powering ON. I thought it to be a fried PCB but looking at the PCB it doesn't look like a fried one. Is there any change if i can buy a PCB from the same model and put in my HDD and it works if there only the problem is PCB and if everything is alright?
What are the chances of swapping new PCB to my HDD to make it work?
If yes what other things should i look even if its from a same HDD?
example .. the firmwire etc..
This is my first post i hope i get some help.
Regards.
 Post subject: Re: Seagate 500GB (ST9500325AS) 5400rpm PCB Problem
PostPosted: March 24th, 2011, 11:40
Post a high quality photo of the PCB, component side up. We can start from there.
Data Recovery Cape Town
PostPosted: March 29th, 2011, 0:59
if i swap the pcb with same model number and firmwire
will it work?
PostPosted: March 29th, 2011, 3:09
will it work?
No it won't absolutely not.
You WILL need to at least transfer the ROM chip, which on these is a fiddly little bugger!
PostPosted: March 29th, 2011, 15:50
HD images please tell me if its repairable ? where is rom is there any idential board from which i don't need to replace the rom?
File comment: ic chip
File comment: disk
File comment: BURNED HERE
File comment: PCB
PostPosted: March 29th, 2011, 16:12
if i am in a market to buy new disk and how can i know that it has same ROM version? and its identical without un-screwing it.
I have many accounts in my HDD i need it soon pls somebody help me!
PostPosted: March 29th, 2011, 16:21
I can tell you right away - the ROM will not be identical between any drives of this model
PostPosted: March 29th, 2011, 16:23
whats the next thing i can do? diode is blown away so if i remove it ? can i swap the diode but there is 1 c of damage in pcb too
PostPosted: March 29th, 2011, 16:31
Swap ROM on a good PCB
PostPosted: March 29th, 2011, 16:35
in this pics where's the Rom?
PostPosted: March 29th, 2011, 16:39
ok i have seen many photos i know where's the ROM now..
so i can buy any Disk or with same FW ?
PostPosted: March 29th, 2011, 17:08
Doomer is absolutely correct, all the PCB's on these are unique.
The ROM is the 8-leg chip top-right of the last pic, but be VERY careful indeed, these chips are very tricky to move and easily break.
PostPosted: March 30th, 2011, 4:39
PostPosted: March 30th, 2011, 5:51
Same disk model, but make sure PCB p/n is same also.
PostPosted: March 30th, 2011, 16:51
Use a digital multimeter (US$10) to measure the resistance of the 5V TVS diode (marking KE?) near the SATA power connector. Also measure the resistance between the ground and +5V pins at the connector.
http://pinouts.ru/Power/sata-power_pinout.shtml
You say that the "diode is blown away". What do you mean by that?
PostPosted: April 7th, 2011, 6:44
i think the diode is shorted .. i'm having another hhd board for diode but this one is IDE and the size of the diode is same its writting B2 on the top on IDE diode and XE5 OR KE5 on SATA diode (current disk)
should i just cut the diode and see if it spins?
i have done measured Resistance in my life i am ready to buy a mutimeter and measure it . but i will need a guide.
PostPosted: April 7th, 2011, 7:01
i was touching the diode and it came off very clean both the legs were secure.
i thought i should try the disk without diode and i tried and still its not powering.
PostPosted: April 7th, 2011, 7:03
I can see in the picture you posted that the diode has burnt.
So even if you just remove the diode the Hdd should start working, no need to put another one. These diodes are for protecting drives from higher voltages and surges
PostPosted: April 7th, 2011, 7:06
still circuit is not complete to power it up.. oer there is some hinderance
PostPosted: April 7th, 2011, 7:13
May be voltage is not reaching to the circuit.
check for any track breakage
Users browsing this forum: Google [Bot] and 96 guests
