 Post subject: Unlock SEAGATE PIPLINE
PostPosted: April 3rd, 2011, 12:03
Hi.Ihave an SEAGATE PIPLINE HD2 500GB,and its have password.PLEASSSSSSS someone can help me how to figure and erase password?What archives i need to put into a floppydisk?I downloaded some but i have an error NO DRQ,and i cant copy 22.bin on to floppy.Thanks a lot.
 Post subject: Re: SEAGATE PIPLINE
PostPosted: April 3rd, 2011, 12:07
Without special tools, I don't think you can solve it.
ACELab partner
 Post subject: Re: Unlock SEAGATE PIPLINE
PostPosted: April 3rd, 2011, 12:16
Its all i want to know.And if i paid a pro to do it,how much money we are talking about(in €).
PostPosted: April 3rd, 2011, 14:14
hi
Do you know if the password is the user password or the master password?
If only the user password is set, then you can unlock with the default master password.
http://ipv5.wordpress.com/2008/04/14/list-of-hard-disk-ata-master-passwords/
This page lists known ata master passwords, and he mentions “Seagate” +25 spaces as a possibility.
PostPosted: April 4th, 2011, 3:37
Hi.The HDD its from an satelite tunner.I dont know if the password is user or master password.
PostPosted: April 4th, 2011, 5:24
If its from a satelite tuner its quite possible the manufacturer has set a password so that the drive can only be used in the satelite tuner. If this is the case then they have likely set the master password.
I would suggest that you use either mhdd or atapwd to attempt to unlock the drive with the master password 'Seagate' + 25 spaces. If this does not work, the only other thing i can think to try is using the satelite tuner manufacturers name in various forms; ie if it is made by sony then try master password 'sony' + 28 spaces; try sonysonysonysonysonysonysonysony ; try it with capital S; try every variation you can think of.
The chances of success are pretty low, but its worth spending half an hour trying every password you can think of before paying to have it unlocked.
good luck :)
PostPosted: April 4th, 2011, 5:59
Hi.In a spanish forum(where i am from)a guy speaks about this password but for WD HDD.He says that his password is like D2 69 ...... .
PostPosted: April 4th, 2011, 6:22
the 'D2 69 ..' looks like the start of a hexidecimal string. There are scripts for the program mhdd that allow you to copy the security module of the secured area on some western digital hard disks to a file; this information is in hexidecimal and must be converted to recover the password. However i do not know of any scripts like this for seagate hard disks so this information is not really any use to you.
For your hard disk the only solution i know of is to guess the password or use expensive equipment.
Download hiren's boot cd which contains atapwd and i think mhdd as well. Boot your computer from the hirens boot cd and choose either atapwd or mhdd. Then use the option to unlock the drive with master password and try the 'Seagate + 25 spaces' password, and any others you can think of.
PostPosted: April 4th, 2011, 7:29
WD and SEAGATE are a total different drive.
So said, any decent professional with the right tooling can either ERASE your drive and unlock it for re-use OR unlock it.
It is highly possible that signing papers about property of the drive and responsibility will be required as nobody want to have trouble with law enforcement for this as the drive can be stolen or contain copyrighted material and would be a breaching of LA or RM to use them.
Wouldn't be nice to address all these requests on other better places ?
PostPosted: April 4th, 2011, 8:26
The drive its on my own.I buy for it.The receiver its broken and i want to re use it.I think its better to see a profesional.Regards.
PostPosted: April 4th, 2011, 8:28
Check the security level first. If you unlock a drive with master password and security is set to max it starts an internal security wipe.
If security is set to max you will definately need some help with this. Dont even think about using any Master Passwords on it.
https://www.mjm.co.uk/
PostPosted: April 4th, 2011, 9:14
The security is set to MAX....
PostPosted: April 6th, 2011, 4:31
hdat2 tells me that master password has been changed.Damn receiver........
PostPosted: April 6th, 2011, 5:57
it's part of DRM...
PostPosted: April 6th, 2011, 7:33
Use SeDiv. With its help (even in demo ver) you can unlock it.
data recovery Poland
PostPosted: April 7th, 2011, 4:42
Hi.This program how do i use it??
PostPosted: April 7th, 2011, 5:19
Search the forum
PostPosted: April 10th, 2011, 6:07
http://forums.seagate.com/t5/Internal-A ... 555#M18830
http://forums.seagate.com/t5/Barracuda- ... 234#M20842
sediv-hdd-seagate-terminal-for-windows-t11980.html
PostPosted: October 22nd, 2015, 20:22
is SEDIV can do this case?
thanks
Users browsing this forum: No registered users and 243 guests
