 Post subject: Maxtor DiamondMax 22 STM3500320AS
PostPosted: September 23rd, 2010, 12:23
Hi
Today I get this disk, that's not recognized by BIOS or Maxtor SD Doctor.
The client also have the exactly same disk, to use as donor.
Tried to swap PCB, but the donor PCB on the bad drive, it starts clicking and a bunch of noises.
Tried to read FW from Donor Drive, I get errors from Doctor, but it's recognized ok and works OK on the PC.
Just by swapping the PCB, shouldn't work? Or need to exchange ROM's?
PS: here's the picture of them.
ACELab partner
 Post subject: Re: Maxtor DiamondMax 22 STM3500320AS
PostPosted: September 23rd, 2010, 12:25
You should be using different utility
www.datarecoveryne.com
PostPosted: September 23rd, 2010, 12:29
Like what?
ACELab partner
PostPosted: September 23rd, 2010, 12:33
Look at the drive. Does it look like any other drive/s?
PostPosted: September 23rd, 2010, 12:39
Looks like a Seagate. Shit... Is that it??
ACELab partner
PostPosted: September 23rd, 2010, 12:43
Bingo
PostPosted: September 23rd, 2010, 12:50
Thanks Guys.
Let's see what can be done.
ACELab partner
PostPosted: September 23rd, 2010, 16:37
MX15 firmware was affected by Seagate's 7200.11 BSY bug. The same fix applies.
http://forums.seagate.com/stx/board/mes ... 467#M18467
PostPosted: September 24th, 2010, 4:48
Thanks Guys. Problem Solved with the right tool.
Fuc... name change :evil: :evil:
ACELab partner
PostPosted: September 24th, 2010, 6:23
Nice one :D
Free Solutions
PostPosted: April 5th, 2011, 9:38
I have a same problem, please HELP... i have a donor HDD too... THANKS
PostPosted: April 5th, 2011, 10:18
Put the original PCB back on ur drive and read the link Fzabkar provided in this topic.
PostPosted: April 5th, 2011, 10:25
Alexii, you forgot :
... IF and only IF the problem was correctly addressed.
PostPosted: April 5th, 2011, 13:15
true =) IF Ervin is sure that the problem is indeed the same as the OP has - then link might help in solving it.
PostPosted: April 5th, 2011, 19:44
Thanks to all, I solve the problem... I used infinity box (my friend have a mobile repair shop and I take it from him) and I get your links... step by step and I'm done, all data is recovered... Thanks to all again :mrgreen:
Users browsing this forum: Google [Bot] and 45 guests
