 Post subject: microSD (1GB) with a password set by a Nokia phone,how wipe?
PostPosted: November 2nd, 2010, 7:54
I have a microSD (1GB) with a password set by a Nokia phone, datas aren't important.
If I insert it in the Nokia phone it can be read/write and even formatted (but it still protected after this), instead if I insert it in the card reader or in other phones it isn't recognized.
There is a way to force a card reader to ignore the "status" and wipe out everything?
Or there is a special card reader that support these things?
 Post subject: Re: microSD (1GB) with a password set by a Nokia phone,how wipe?
PostPosted: November 11th, 2010, 14:32
I wasn't even aware that microSD cards could be password protected. I guess this proves just how much of a n00b I am. I suppose if you're having difficulty altering the contents of the card (without a password), you aught to call up the manufacturer or bring it to a professional. Many of them can follow a procedure/shortcut that will eliminate the password factor.
Olivia
I need to find someone with good VMware Hosting!
PostPosted: February 4th, 2011, 6:14
You need to insert the MicroSD card back into the Nokia phone then decrypt/remove it's password. Considering you still have the phone.
PostPosted: February 4th, 2011, 22:38
I have the phone but not the password.
PostPosted: February 12th, 2011, 6:42
if you can update the nokia phone software and have the cables
it will reset the password to default
12345 or 00000
then you can format it
PostPosted: April 7th, 2011, 12:59
in phone is file wich contain password. i cant remember filename. try google.
PostPosted: September 5th, 2011, 22:18
hi , next time put card in another nokia e series phone, eg e90, e71, e72 etc and format the card, then recover data.
it works 100%.
regards
gopal
Users browsing this forum: No registered users and 21 guests
