 Post subject: Seagate ST3808110AS 80GB (electric problem)
PostPosted: April 11th, 2011, 4:47
Seagate ST3808110AS 80GB electric off and on quickly and stop working.
I bought identical hdd (model #,p/n # ,fw and made in china). I swapped the PCB
but not detected in bios .
Pls I need your easy advice (change head or change platter).
Note :Did need head alignment ?
Thank u
 Post subject: Re: Seagate ST3808110AS 80GB (electric problem)
PostPosted: April 11th, 2011, 7:15
According to your question my friend here
you said:
1) I bought identical hdd (model #,p/n # ,fw and made in china). I swapped the PCB
2) Pls I need your easy advice (change head or change platter).
based on the facts here, seems that you are new on this, swap pcb will never work without the ROM
and since you went to (2) direct, i recommend a Pro. DR for your case, you will need alot of knowledge n practice on Head/platter work.
good luck
PostPosted: April 11th, 2011, 19:52
You need to transfer the 8-pin serial flash memory chip from patient to donor. It stores unique, drive specific, "adaptive" information.
This chip is located at the top right of this photo:
http://admin.moguling.com/Upload/drives ... com/14.jpg
There is a "25" in the part number.
Did you check the two TVS diodes below the SATA power connector? Does your replacement PCB spin up the drive?
PostPosted: April 14th, 2011, 11:51
WD2500BEVS 250gb laptop hdd not recognize,my laptop quickly off due to weak battery.now hdd spinning but not recognize..what i should do?my data have been lost.i want to recover my data. please guide me soon...thanks :(
PostPosted: April 14th, 2011, 12:32
YOU SHOULD START NEW TOPIC BASED ON YOUR PROBLEM!
Answering your question : the drive need proper diagnostic of your drive, which require tools and knowledge.
You could try to connect it to another computer in order to see if the problem is with your laptop or with the drive.
IMHO if you have valuable data send it so some local pro!
DataRecovery.bg
PostPosted: April 15th, 2011, 9:32
thanks for quick reply.
sir i want to repair it so please guide me in to repair process and its supporting equipments.i am an electronics engineer...and i provide gsm and computer hardware services. thanks
PostPosted: April 15th, 2011, 9:47
@shuaib_kashish:
As Samo told you - Start a new thread and stop hijacking this one!.
It is unlikely that you will get help, when you deliberately break the normal rules of netiquette (please research that topic - it will help you on web forums like this one).
When you start a new thread, then I have a couple of questions ready to ask you, but you have to start a new thread first. :) Is that clear enough?
Users browsing this forum: Google [Bot], shubhsinghal and 93 guests
