 Post subject: Seagate Go 320GB external HDD
PostPosted: April 12th, 2011, 5:45
Okay. So the usb port broke off of the circuit board. Where can I find a new one to swap it out?
 Post subject: Re: Seagate Go 320GB external HDD
PostPosted: April 12th, 2011, 5:46
also, just to clarify i need the entire circuit board that plugs in to the disk drive.
PostPosted: April 12th, 2011, 5:57
You should be able to use any third party 2.5" USB-SATA enclosure.
PostPosted: April 12th, 2011, 13:09
Are you sure it is on the PCB board on this one? Can you remove it from the enclosure and really examine the PCB board on this one before going out and buying a new one. On this there are adaptives that have to be moved over.
Take a photo of this broken USB port you are speaking of and post it here. Normally these are SATA or IDE connected to the enclosure or MB on them.
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 79 guests
