 Post subject: FW Request Maxtor DiamondMax Plus 8 6E040L0STD NAR61HAO
PostPosted: April 12th, 2011, 16:02
Hi, Everybody...
I need fw for a maxtor hard drive of 40 gb....
DiamondMax Plus 8
6E040L0STD
CODE NAR61HAO
Serial E924W4JE...
LBA: 80293248
This Drive show status ready, but I can't see any parameters... I hope someone can help me.... I want to try restore the firmware but I don't have the Sa-C boot mod... :(
If someone have it, I will appreciate if can help me...
Thanks Alot...
 Post subject: Re: FW Request Maxtor DiamondMax Plus 8 6E040L0STD NAR61HAO
PostPosted: April 13th, 2011, 6:09
to fix loosing data or you need data from it?
PostPosted: April 13th, 2011, 17:33
I need the data...
the model is 6E040L0711205
CODE: NAR61HA0
SERIAL E924W4JE
LBA 80293248
I have Nar61590 but not this model... :(
Thanks Alot....
PostPosted: April 13th, 2011, 18:24
Here you go...
http://files.hddguru.com/download/PC-30 ... E-KMBA.rar
PostPosted: April 13th, 2011, 19:55
Thanks N.C., for your help
But I don't have pc-3k Yet,
I need the file boot.cod ....., when i connect the HDD and turn on, in HD Doctor for maxtor, this drive show status ready, but none parameters.... show N40P and NAR63G4Z, But the CODE in label is NAR61HAO... I can't access nothing, not p-list, not modules...nothing....
just NAR63G4Z and LBA 0
Therefore, I want to try to repair the fw problem, but I don't have the file boot.cod.... :(
PostPosted: April 13th, 2011, 20:23
Hi, do you have login access to Salvation forum yet? There are some there. The closest I have is 6E040L0-NAR61590-E1JS... Maybe PC-3000 file will work, have not had chance to test.
PostPosted: April 14th, 2011, 1:23
Yes, I have access to salvation data forum, and i search for this fw, but i can't find it... :(... nearest is NAr61590... i search in the forum, but today I will post a message to see if something have this fw....and can help me
Thanks....
PostPosted: April 14th, 2011, 11:55
if you want SA access (only), you can use any loader (or boot code) wich matches this HW from any NAR61xxx firmware.
PostPosted: April 17th, 2011, 16:37
Thanks Friends...
Now I have access to firmware.... now show status ready and I can see the parameters....
MAXTOR 6E040L0 NAR61HA0 AND LBA correctly... I see the Modules but if I save SA Primary, Have error In this Modules....18,27,34,36,40,52,65,99,112,152,167.....
If I save fw in SA Secondary...have error in this Modules.... 0-22,27,34-45,51, 65-67,70,71,73-99,104-107,116-119,121-146,155-157,159-164 and 167-173....In fact many, many modules damages....
If I save groups have error in this groups...0,1,2,3,5,6,7.... 4 ,8 y 9 are ok...
If I save ram is ok....
If I try to save ROM.... program is Freeze...... ... and send me access denied...
I attach pictures of errors...
I try to upload good firmware, but i can't :(.... I use to upload firmware 6E040LO NAR61HAO E92....)... i try too upload only damage modules... if I try to see sectors... show only 6666...and send error....
If someone can give me any idea how to fix it?
Thanks in advance....
File comment: Errors in Nar61HAO
Errors in 6E040L0 NAR61HA0.rar [480.06 KiB]
Downloaded 844 times
Users browsing this forum: No registered users and 0 guests
