 Post subject: HDD Lowlevel Format Software not working
PostPosted: April 16th, 2011, 18:51
Hello. I am new to this forums so this topic may have been covered and I just did not see it.
I have used HDD's Low Level Formater software for some time on a computer running Vista. I just upgraded the OS (Clean Install). I installed the HDD Formating software and it worked fine for a few days. The other day when I opened up the software, the software did not show any of the hard drives on the system. I uninstalled the software and reinstalled the software, and it worked fine. The problem is that the min I close the software after it has been installed and then reopen it; the software does not show any hard drives including the system drives.
Any sugestions will be greatly appreciated.
Thank you for your time.
Comptec.
 Post subject: Re: HDD Lowlevel Format Software not working
PostPosted: May 3rd, 2011, 23:04
For the archives, the OP has repeated the same question here:
problems-with-hdd-low-level-format-software-t19292.html
Therefore this thread should not be used, to avoid duplication with the above linked thread.
