 Post subject: noise sound
PostPosted: April 18th, 2011, 17:05
from a 2.5 hitachi i attached this sound noise
any advise will be appreciate,
i suspect motor jammed-> i will try to brutal force the motor into the clean room,
but i wanted to post here for a confirmation from a somebody more expert..
:roll:
Clip audio 01.zip [89.36 KiB]
Downloaded 298 times
 Post subject: Re: noise sound
PostPosted: April 18th, 2011, 17:47
Mi sembra che usi questo metodo un po' troppo... deve essere un'abitudine :mrgreen: .... guarda che spostare l'insieme dei piatti su uno chassis funzionante quando serve serve ! E' piu' facile a dirsi che a farsi, comunque :(.
P.S. sei proprio sicuro che il motore sia bloccato?
I noticed that you use this method too often... Must be an habit :mrgreen: .... please notice that sometimes,when needed, you have to move platter pack to a good chassis!
Easier to say than do, anyway :(
P.S. are you really sure the motor is seized ?
PostPosted: April 18th, 2011, 17:54
[/quote]
P.S. are you really sure the motor is seized ?[/quote]
well i am not sure - tomorrow i will enter cleanroom and check it out.
last drive, 7200.11, needed a special platter swap ( i have SD'tools,and do not allow me the work :cry: )
this drive instead do not need a special platter swap, so i am wating the donor, until than ,i can only be patient and wait.
one thing that i'm asking myself: once i will loose the alignment of the platters, another DR company can still recover the data?
PostPosted: April 18th, 2011, 17:59
Si ma se prima costava "x" in quel caso costa una fucilata ! (ammesso e non concesso che si riesca e in tempi ragionevoli)
Yes but if originally the cost was "x" , then it will cost an arm and a leg ! (assuming it can be done and in a reasonable amount of time)
PostPosted: April 18th, 2011, 18:06
could you be nice and explain the reason/reasons it will increase the cost of data recovery?
:roll:
PostPosted: April 19th, 2011, 1:56
Semplice : quanti sanno come risolverlo e cosa serve ? Sono cose che si pagano care - non posso darti altri dettagli.
Simple : how many people know how to do it and what is needed ? These things are damn expensive - can't give more details.
Users browsing this forum: No registered users and 64 guests
