 Post subject: Transcend 640 GB external hard disk
PostPosted: April 19th, 2011, 9:19
Hi all,
I am using a Transcend 640GB hard disk which is USB compatible. Suddenly it was not responded during a data transfer and it shows RAW as its file format.
I just tried windows disk management utility and sevaral low level formatting softwares to fix this problem. When i m using the Win Disk Mgt tool, the formatting is proceeding, but it is getting not responded at the last stage.
Any suggestions???? please tell me...
Thanks in advance....
 Post subject: Re: Transcend 640 GB external hard disk
PostPosted: April 20th, 2011, 8:18
what OS you are using ?
RAID/Server Recovery
PostPosted: April 20th, 2011, 9:23
The drive may have errors.
Zero Alpha: zeroalpha.com.au
PostPosted: April 20th, 2011, 9:53
Are you trying to recover the existing data or just want to format it to use it?
If your try to recover data then you could try R-Studio, select the drive & scan it
loki
Users browsing this forum: Google [Bot], michael chiklis and 310 guests
