 Post subject: ST9500325AS: impotent donor
PostPosted: April 26th, 2011, 23:05
Help me, please! I have troubles with the subj from a portable USB set. It makes sharp noise, don't recognized by OS, slow OS loading so as the full stop. I've buy a donor with the same mark. But a simple interchanginig of the boards did'nt take an effect: BIOS (and OS) had see a zero volume of a disk. Could I make somnething "at home", because there are no service at all in our small town?
Thanks.
 Post subject: Re: ST9500325AS: impotent donor
PostPosted: April 27th, 2011, 3:32
Looks like your drive has some mechanical problem inside HMA. Where are you from exactly? If you need data from it i will send you contacts someone nearest you.
Angel Data Recovery
PostPosted: April 27th, 2011, 7:22
Have you some contacts on North Ural (Perm region) from Kiev???
Mechanical problems are'nt present because the block is very silent with this new board. It's turning well, but BIOS cannot determine the size.
PostPosted: April 27th, 2011, 8:35
В Перьми есть мастер который занимаетмся дисками много лет.
Константин Нездиминов.
www.datarecoveryne.com
PostPosted: April 27th, 2011, 12:05
Спасибо, если не получится по-другому, я обращусь к нему. Но мне до Перми дальше, чем от Москвы до Владимира.
Как Вы считаете, я сам ничего сделать не смогу, имея под рукой донора?
PostPosted: April 27th, 2011, 16:53
Unfortunately, donor won't help you to solve this problem.
Users browsing this forum: Google [Bot] and 228 guests
