 Post subject: What do you use for nand recovery.
PostPosted: April 27th, 2011, 14:45
Boss man decided to move to nand recovery side of the data recovery industry. Before that we always outsourced the jobs that had faulty controller and required nand readers and Rubiks cube solution after =) Now he is planing to get PC3K flash.
The question i have is this. Infrared station. Honest , delicate , durable etc =) What would you suggest. The Ebay is full with cheap stations from China for like 200 USD but we wont skimp that much on equipment we will be using a lot.
Ty all for ur time.
Alex.
 Post subject: Re: What do you use for nand recovery.
PostPosted: April 27th, 2011, 16:12
save your money on PC3000 flash and get soft center. It is much better and the forums there are full of very good info.
Good Luck
PostPosted: April 28th, 2011, 5:58
Banned User
Based on a lot of forum reading and speaking with people in the industry, soft center is the better buy.
PostPosted: April 28th, 2011, 10:06
Heya all, ty for answers , however the question was not as much about the nand readers but about infrared stations =) I think the name for a topic i chose is a bit misleading. Apologies.
PostPosted: April 28th, 2011, 10:35
I understood just wanted to point out that you should get soft center :)
