 Post subject: WD10EADS-00L5B1 torment.
PostPosted: May 4th, 2011, 8:29
Drive- WD10EADS-00L5B1 1TB
Using pc-3K
Ok, so client sent in the drive, stays busy on the register, slight calibration sounds and spinning.
Pop the drive into kernel mode and can get ROM and RAM.
Do a quick ROM head map change by disabling head 2.
(2),3,4,5,6,7
Pop the jumpers out and repower the drive and she comes ready, yay i foolishly thought.
Into the Kermit utility and get copy 0 of the SA, master resource copy into the DB.
Go to image to another TB and nada.. every sector errors.
Built a head map (came as 0 1 2 3 4 5) and turned off 0 just incase but to no avail.
Then tried all again and then another ROM head change to enable head 2 after it come ready and still zip.
Now short of a HSA swap am I missing something?
Thanks in advance
Rick.
DataWreck Data Recovery Services
www.DataWreck.co.uk
 Post subject: Re: WD10EADS-00L5B1 torment.
PostPosted: May 4th, 2011, 8:43
When you say every sector errors in DE, what kind of errors?
Data Recovery Cape Town
PostPosted: May 4th, 2011, 8:53
Error Add Mark not found, fire a soft reset at it then goes busy for a seccond and comes ready again.
www.DataWreck.co.uk
PostPosted: May 4th, 2011, 9:08
A bit of reading indicates that one of the issues could be a failing head therefore the translator isn't loading properly.
Perhaps try disabling some different heads?
Another idea was to try modifying DE config and setting "Block size for reading" from 256 to 2 or 4.
PostPosted: May 4th, 2011, 10:39
uhm nice idea, i never tried, nut just now i have a drive whic is imaging by 3 heads instead than 4..
will give a try later on!
PostPosted: May 4th, 2011, 11:13
Yeah, head 2 had failed which is why it was turned off.
if I turn any more of the heads off recovery will be low quality.
And block size for reading makes no diff im afriad. (thanks for the quick response though)
However one thing I did note was that its out of a WD caddy with a inito chip...
Is it maybe smartwear getting in the way?
www.DataWreck.co.uk
PostPosted: May 4th, 2011, 11:55
I would send it to an expert
PostPosted: May 5th, 2011, 4:03
I don't know enough to give any more input. If it were just a practice drive you were fiddling with to gain experience with then it would be easier to recommend things to try perhaps, but seeing that it's a client's drive there are risks to trying something that could make matters worse. I'd be interested to know what the outcome is once it's solved :roll:
PostPosted: May 5th, 2011, 5:11
RAM head map edit, rather than ROM
PostPosted: May 5th, 2011, 9:21
Not liking the head RAM headmap change.
Put the drive into kernel
Techno mode key
Techno mode key......................... : Ok
ROM:
Flash Dir reading....................... : Ok
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.CEE
ROM generation.......................... : 05.CEE
Link table version...................... : 04.3F.
Heads configuration..................... : by map
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Head map................................ : 2,3,4,5,6,7
ROM Firmware version.................... : 000500CE
0 0
1 0
2 0
3 0
4 0
5 0
Map has incorrect bytes
Kermit
Lib: Kermit
Offset (hex): 4000000
Map Size: 8
\x06\x02\x03\x04\x05\x06\x07\x00\x00
\x06\x00\x02\x03\x04\x05\x06\x07\x00\x00
Know I know some others out there have had the same issue with map has incorrect size and may have some insight (Luke? please :) ) , I get a lot of WD drives but ive not seen this error personally after being able to get a copy of the SA. And im also now unsure about the worth of spending time swapping the heads..
Cheers guys
Rick.
www.DataWreck.co.uk
PostPosted: May 5th, 2011, 9:40
Do I need to be ID=11h editing from another FW version or am I just heading down the wrong path?
Or 0A from the rom moduals?
www.DataWreck.co.uk
PostPosted: May 5th, 2011, 11:24
I would do a smart hotswap on this.
Give me a call if you want further details Rick :-)
PostPosted: May 5th, 2011, 12:03
I agree smart hotswap. Also check SA for errors, smart hotswap won't work if theres errors in mods. If that doesn't help then you should send it to a pro.
Users browsing this forum: No registered users and 201 guests
