 Post subject: Samsung HM502JX
PostPosted: May 11th, 2011, 13:34
Okay, so a friend's hard drive "suddenly" stopped working properly. She says that she tried to use it and the computer notified her that she should format the hard drive, she rejected this and when she got home the hard drive did not work. The drive does not show up in the Device Manager but the light goes on and it does spin, but it makes a very subtle beep every few seconds. I am not a professional, I am more of an enthusiast. Any suggestions would be appreciated. I have tried to search but I found nothing.
Thank You
 Post subject: Re: Samsung HM502JX
PostPosted: May 11th, 2011, 14:23
Are you 100 percent sure it spins ? The beeps u described and the fact that the drive is 2.5 seems like a sticktion problem to me m8...
PostPosted: May 11th, 2011, 14:50
Well, it feels like it is spinning and also sounds like it, before every beep if you listen very closely it sounds like the sound effect they use in the movies to simulate a laser charging...that is the best discription I got.
PostPosted: May 11th, 2011, 15:41
No it can be and is not stiction. Is it like a 'laser zap' followed by an about 1000 Hz beep of no more than 1 / 1.5 seconds duration? 8)
PostPosted: May 11th, 2011, 15:55
Ah, Slayer, another fellow South African 8)
Data Recovery Cape Town
PostPosted: May 12th, 2011, 3:01
Yes, that is what its like. Any idea of fixing it?
PostPosted: May 12th, 2011, 12:18
I'm sure BlackST will give some insight to your problem :wink:
PostPosted: May 13th, 2011, 4:42
Or maybe it's a 'trade secret' :wink:
Users browsing this forum: Google [Bot] and 70 guests
