 Post subject: ST31600815AS BSY state
PostPosted: May 12th, 2011, 11:08
Anybody has success fixing 7200.10 busy issue?
Firmware ST31600815AS FW:3.CHH
Thanks.
 Post subject: Re: ST31600815AS BSY state
PostPosted: May 12th, 2011, 11:26
Always. It depends on the cause 8) .
P.s. There's no .1x BSY problem, but multiple causes instead.
PostPosted: May 12th, 2011, 13:58
BlackST
The problem is similar to the Seagate 7200.11 disks that hang. Althouth, this one does not give the usual error for brick drives. Head and pcb swap did not do anything for it.
Thanks for the reply.
PostPosted: May 12th, 2011, 15:47
Corrupt ROM in a certain way and it will hang, corrupt some modules and it will hang, screw some part of the service area and it will hang, partially rewrite the firmware and it will hang....
Multiple starting points, same result and symptom. Naturally the "internet fix" won't work.
PostPosted: May 12th, 2011, 16:13
Yeah, I know. This is a different drive. Fist time seeing this issue with these drives. In two weeks, got clients calling about same issue. I just wanted to know if you guys have seen the issue. I do not see Seagate offering update for them. Maybe it is a fairly new problem, or I am just find out now.
Thanks.
PostPosted: May 13th, 2011, 1:32
PM sent
PostPosted: June 15th, 2011, 13:35
ROb,
Good day,
Just trying to ask if you have idea on repairing this kind of error, got a ST3808110AS busy state, no knocking sounds, 0mb also. Thanks
reagrds,
nzo
"Your arrogance doesn't cheapen me."
Users browsing this forum: Majestic-12 [Bot] and 60 guests
