 Post subject: swapped HSA, the arm doesn't move
PostPosted: May 13th, 2011, 8:14
saegate momentus 5400.4 120gb 2,5' after a hsa swap, the arm doesn't move
video in attachmcan you hear a weak buzzy noise?
13052011010.rar [1.63 MiB]
Downloaded 326 times
 Post subject: Re: swapped HSA, the arm doesn't move
PostPosted: May 13th, 2011, 9:36
2 questions: what happened before head swap? Have you tried to close the lid and power up the drive to check if heads move?
PostPosted: May 13th, 2011, 11:05
Hi, the hdd had 1 of the 2 heads crashed ( inspected into the clean bench )
Yes i tried to close the lid, but same result.
PostPosted: May 13th, 2011, 11:26
Are you sure there's nothing wrong bellow the magnet preventing the heads to move?
Have you inserted PCB screws?
PostPosted: May 16th, 2011, 2:10
Hi, it is possible moving by finger the arm, and i checked twice the pcb board.
uhm..any other idea? if not i will try to put back the HSA to the donor to see if it works correctly.
PostPosted: May 16th, 2011, 3:50
Well, that could be an option.
I've seen several situations in which heads didn't move, since missing PCB screws, bad PCB, bad pre-amp, etc.
PostPosted: May 17th, 2011, 1:05
i swapped back, the arm doesn't move even in the donor, so it's sure it's demaged. :oops:
PostPosted: May 17th, 2011, 3:06
So, there are 2 options. Or your PCB is killing your preamp or you damaged it while replacing it.
PostPosted: May 17th, 2011, 3:16
thanx for clarification.
i do have still my last HSA having a 'last chance try'. i am quite sure i didn't touch the heads while performing the swap.
i am supposing a static.
PostPosted: May 17th, 2011, 3:30
Well, give it one more try and check the results.
Users browsing this forum: Google [Bot] and 89 guests
