Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: May 15th, 2011, 14:16
I know this is getting repetative and annoying for those who know how to do this but can somebody please help me find my password? Thanks in advance.
File comment: Bin22
22.rar [318 Bytes]
Downloaded 3199 times
PostPosted: May 15th, 2011, 14:44
Reptilewing wrote:
The psw is retrieved! :) Thank you for such a great thread!:)
How did you end up getting the password ?
PostPosted: May 15th, 2011, 17:16
Password received THANK YOU SO MUCH!!!
PostPosted: May 15th, 2011, 17:36
Look for an 01 07 byte pair. The password is in the following 32 bytes and is padded with zeros. It will be encoded in ASCII if it was generated from application software. Otherwise, if it was generated via BIOS, such as in a laptop, then it will be encoded as keyboard scan codes.
Here are the keyboard scan codes for my MS wireless keyboard:
http://www.users.on.net/~fzabkar/MSKeyLog.TXT
Use the "make" codes when decoding your password bytes.
This simple DOS utility will echo the make and break scan codes of each keypress:
http://www.users.on.net/~fzabkar/SCAN.COM
Have you ever thought why the BIOS setup menu is restricted to Fn keys and cursor control keys, eg PgUp, PgDown, Home, End, Del, arrow keys, Space, Enter, Alt, Esc, Ctrl? I believe it's because BIOS has no way of knowing which international keyboard layout is in use, so it needs to use those keys which are universal. These universal keys have consistent scan codes.
Similarly, when you set a HDD password via BIOS, the scan codes of each key are used rather than their ASCII values. I think of scan codes as key numbers. For example, a particular key on a 101-key US keyboard may be key #30 with an ASCII value of 65 (an "A"), whereas the same key on a Japanese keyboard would have a different ASCII value, although its scan code would still be the same. To think of it in another way, imagine how you would identify a particular key if all the key tops were blank.
Note that if you have set the password via BIOS in a laptop, say, and you then attach the drive to a different machine, eg a Windows desktop, you will then need to send the password bytes via a file. If you try sending the password as ASCII codes, then the password challenge will fail.
A possible Windows solution would be an application such as Victoria for Windows. A DOS solution would be MHDD.
PostPosted: May 29th, 2011, 12:22
Hi all
i need help..........
i have tried for many days to unlock/remove password on my wd scorpio hdd 80Gb with no success
tried default passwords ......... none of those works
cant use atapwd because this hdd doesn't print an error code when entering wrong passwds
managed to run dump script on mhdd and tried to read the passwd but no chance with it
converted also bit per bit from hex to dec but this also doesn't work cuz i have an "08" value that delete the previous one
here is the dump
22.rar [825 Bytes]
Downloaded 2311 times
thanks in advance
PostPosted: June 15th, 2011, 11:18
can u tell me where is the pass here?? if it is after 01 07 bytes it is something with eight 0`s but i cant figure it out thnx
PostPosted: June 15th, 2011, 17:30
Is the drive installed in a laptop? USB enclosure?
How are you entering the password? BIOS or application software?
PostPosted: June 18th, 2011, 5:41
can anyone tell me what wrong with my drive?
I attach the hex dump using victoria.
WD1600BEVT.7z [325 Bytes]
Downloaded 1739 times
PostPosted: June 18th, 2011, 19:24
You have only attached one BIN file. The password appears to be in a subsequent BIN.
-Franc
PostPosted: June 20th, 2011, 16:16
0000 : 7A 42 FF 3F 37 C8 10 00 00 00 00 00 3F 00 00 00 zB˙?7Č.....?... :
0001 : 00 00 00 00 20 20 20 20 57 20 2D 44 43 57 56 41 .... W -DCWVA :
0002 : 31 39 34 32 33 31 34 32 00 00 00 40 32 00 31 30 19423142...@2.10 :
0003 : 30 2E 41 30 31 30 44 57 20 43 44 57 30 35 30 30 0.A010DW CDW0500 :
0004 : 56 41 53 56 36 2D 4D 33 42 38 20 30 20 20 20 20 VASV6-M3B8 0 :
0005 : 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80 € :
0006 : 00 00 00 2F 01 40 00 00 00 00 07 00 FF 3F 10 00 .../@.....˙?. :
0007 : 3F 00 10 FC FB 00 10 01 FF FF FF 0F 00 00 07 00 ?.üű.˙˙˙... :
0008 : 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 .x.x.x.x....... :
0009 : 00 00 00 00 00 00 1F 00 06 17 00 00 44 00 40 00 .........D.@. :
000A : FE 01 00 00 6B 74 61 7F 33 47 6B 74 41 BE 23 47 ţ..kta3GktAľ#G :
000B : 7F 40 37 00 37 00 00 00 FD FF 00 00 80 80 08 00 @7.7...ý˙..€€. :
000C : 00 00 00 00 A0 86 01 00 30 60 38 3A 00 00 00 00 .... †.0`8:.... :
000D : 00 00 00 00 00 00 00 00 01 50 E1 4E 78 57 27 DC ........PáNxW'Ü :
000E : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 40 ..............@ :
000F : 1C 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 @.............. :
0010 : 27 01 00 00 00 00 00 00 00 00 D9 16 00 00 00 00 '........Ů.... :
0011 : 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 ............... :
0012 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0013 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0014 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0015 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0016 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0017 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0018 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
0019 : 00 00 00 00 00 00 00 00 00 00 00 00 3F 30 00 00 ............?0.. :
001A : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
001B : 00 00 00 00 00 00 00 00 00 00 00 00 1E 10 00 00 .............. :
001C : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
001D : 00 00 00 00 01 00 00 10 00 00 00 00 00 00 00 00 .............. :
001E : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ :
001F : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A5 43 ..............ĄC :
can u help me plz ? i spent epic time on it
PostPosted: June 20th, 2011, 21:56
@ulotar,
Your data appear to be the 512-byte information block returned by the drive in response to an ATA Identify Device command.
For example, you can see the following information in byte-swapped format:
Model - WDC WD5000AVVS-63M8B0
Firmware - 01.00A01
Serial Number - WD-WCAVnnnnnnnn
Instead of the above, you need to analyse the BIN files that are retrieved from the drive when using the MHDD script described early in this thread.
FYI, there are two words (92 and 128) that report the drive's current security status. AIUI, the Master Password Identifier is normally set to 0xFFFE if no password has ever been set. IIUC, yours has been set once.
Word 92 - 0xFFFD - Master Password Identifier
Word 128 - 0x0127 - Security locked, enabled, supported, not frozen, Security count not expired, Enhanced security erase supported, Master Password Capability = Maximum
PostPosted: June 21st, 2011, 14:12
New to forum and have scanned all of it. I downloaded both 4.5 and 4.6 of mdhh. I copied the sample.mba and created a new "unlock.mba" but when I ran "Batch" then entered "unlock" I get file can't be opened. So, what is the trick to writing the batch script file?
Trying to unlock my 80GB WD 800VE
PostPosted: June 21st, 2011, 17:21
Hi friends i have wd 500 gb with master pass i cant open script in mhdd ? Other prog maybe can read pass area 22.bin ? Thanks sory for english
PRE]
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY PWD AMNF T0NF ABRT IDNF UNCR BBK 00
[WDC WD5000AVVS-63M8B0 ] [ 976,773,168] [ ] [ ]
* Line: CHECKDRQ
! Unknown command
* Line: SECTORSTO = 22.BIN
! Unknown command
* Line: REGS = $D5 $01 $BF $4F $C2 $A0 $B0
! Unknown command
* Line: WAITNBSY
! Unknown command
* Line: CHECKDRQ
! Unknown command
* Line: SECTORSTO = NEXT.BIN
! Unknown command
* End.
| Select a drive : <SHIFT+F3> | 19:27:00
[/PRE]
i want to run this script
;script name: read md
;reads md 02 on WD marwell drives
reset
waitnbsy
regs = $45 $0b $00 $44 $57 $a0 $80
waitnbsy
regs = $d6 $01 $be $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsfrom = cs.bin
regs = $d5 $01 $bf $4f $c2 $a0 $b0
waitnbsy
checkdrq
sectorsto = 21.bin
waitnbsy
checkdrq
sectorsto = 22.bin
waitnbsy
checkdrq
sectorsto = next.bin
; end
PostPosted: June 22nd, 2011, 18:03
Almost All types disks from satelite receiver can be read filles.
Shuld power dekoder with disk and when dekoder start and load shuld put of sata kable without power and put sata to pc. User can copy all files from disk.
ps sory for english and i teach how start script :D
PostPosted: June 25th, 2011, 3:37
Hi, all i manage to extract 22.bin using the previous 22 scripts.
By the way 4.6 got bug that won't allow all scripts to run.
Use the attached 4.5 MHDD from previous-previous page.
HDD that got bad sector can't run 22 scripts.
Already try it but i don't know what the master password is...anybody can help to find the pwd?
WD1600BEVT(lenovo netbook hdd)
I took 1 week to understand how to run mhdd and the scripts but thanks to all this forum.
22.7z [411 Bytes]
Downloaded 1449 times
PostPosted: July 2nd, 2011, 10:07
I have a WD3200BEVT locked with any password.
I dont know how I unlocked this drive.
Can you tell me if it is possible?
PostPosted: July 2nd, 2011, 12:25
Hello I generated a mod with mvr_r and I dont know what is my password.
00000000  52 4F 59 4C 01 00 30 00 02 00 03 00 6D C1 27 63  ROYL..0.....mÁ'c
00000010  30 30 30 38 30 30 30 30 0A 07 08 00 00 00 00 00  00080000........
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000030  1C 00 A2 00 16 00 B8 00 18 00 D0 00 26 00 F6 00  ..¢...¸...Ð.&.ö.
00000040  33 00 8F 01 0C 00 9B 01 12 00 BF 01 04 00 C3 01  3.....›...¿...Ã.
00000050  06 00 C9 01 13 00 DC 01 11 00 ED 01 27 00 14 02  ..É...Ü...í.'...
00000060  12 00 26 02 20 00 46 02 39 00 7F 02 0D 00 8C 02  ..&. .F.9.....Œ.
00000070  0E 00 9A 02 2E 00 C8 02 46 00 0E 03 48 00 29 01  ..š...È.F...H.).
00000080  33 00 5C 01 33 00 AD 01 12 00 56 03 10 00 66 03  3.\.3.....V...f.
00000090  0E 00 74 03 56 00 CA 03 1A 00 E4 03 1D 00 01 04  ..t.V.Ê...ä.....
000000A0  02 00 00 01 57 44 2D 57 58 45 39 30 38 53 33 37  ....WD-WXE908S37
000000B0  36 37 34 00 00 00 00 00 00 01 10 3F 00 00 00 00  674........?....
000000C0  AF EA 42 25 AF EA 42 25 AF EA 42 25 AF EA 42 25  ¯êB%¯êB%¯êB%¯êB%
000000D0  00 01 A4 03 00 00 00 00 07 7F 00 00 06 F4 01 01  ..¤..........ô..
000000E0  10 01 00 0C 08 01 64 00 00 00 00 01 0A 14 00 00  ......d.........
000000F0  00 14 00 00 00 01 00 01 01 00 40 00 40 01 32 00  ..........@.@.2.
00000100  05 07 00 01 00 02 80 00 3C 00 80 00 00 80 08 10  ......€.<.€..€..
00000110  0A 05 0A 24 2E 42 5F 78 80 80 00 08 00 05 03 00  ...$.B_x€€......
00000120  02 00 03 06 00 08 00 04 0F 00 01 01 00 C8 00 00  .............È..
00000130  04 32 00 05 07 00 01 00 02 80 00 C8 00 80 00 00  .2.......€.È.€..
00000140  80 08 10 0A 05 0A 14 28 5F 5F 78 80 80 00 08 00  €......(__x€€...
00000150  05 03 00 02 00 05 06 00 08 00 10 0F 00 01 01 00  ................
00000160  C8 00 00 04 32 00 05 07 00 01 00 02 80 00 C8 00  È...2.......€.È.
00000170  80 00 00 80 08 10 0A 05 0A 14 28 5F 5F 78 80 80  €..€......(__x€€
00000180  00 08 00 05 03 00 02 00 10 07 00 08 00 10 0F 00  ................
00000190  01 00 01 00 01 02 0A 0B 07 05 02 00 01 02 06 02  ................
000001A0  00 00 02 06 00 00 06 04 00 03 02 00 16 00 01 02  ................
000001B0  06 02 00 00 02 03 00 00 06 06 00 05 0A 00 16 00  ................
000001C0  01 01 01 00 01 14 64 00 00 00 01 64 00 00 4E 00  ......d....d..N.
000001D0  00 7E 00 00 07 01 78 03 00 64 00 00 00 03 84 7C  .~....x..d....„|
000001E0  D0 00 0A 00 14 3C 40 00 01 04 0A FA 00 00 01 0E  Ð....<@....ú....
000001F0  00 00 00 02 02 00 0F 32 0C CA FA 0A 32 0A 01 3C  .......2.Êú.2..<
00000200  55 00 01 00 00 20 00 64 00 00 BA 00 19 01 00 00  U.... .d..º.....
00000210  00 00 00 00 00 01 60 02 12 00 22 00 0A 00 00 00  ......`...".....
00000220  00 00 00 01 01 00 00 01 E0 01 0F 0F 01 02 02 0A  ........à.......
00000230  01 02 00 02 02 08 01 00 FF FF 02 03 50 01 1E 64  ........ÿÿ..P..d
00000240  01 11 04 40 0B 02 00 01 00 00 00 00 05 00 00 00  ...@............
00000250  00 00 FF FF 00 00 00 00 12 0A 12 00 00 00 05 00  ..ÿÿ............
00000260  00 00 00 00 1E 00 00 00 00 00 00 00 00 00 4D 00  ..............M.
00000270  29 00 07 00 12 2E 00 00 00 0E 00 00 00 00 05 00  )...............
00000280  01 00 00 00 00 00 00 07 00 01 02 0D 00 01 03 00  ................
00000290  03 01 00 01 00 00 00 00 00 00 00 01 57 44 43 20  ............WDC
000002A0  57 44 33 32 30 30 42 45 56 54 2D 32 32 5A 43 54  WD3200BEVT-22ZCT
000002B0  30 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20  0
000002C0  20 20 20 20 20 20 20 20 00 01 53 7C 42 7C 4C 7C          ..S|B|L|
000002D0  50 5A 4D 53 48 47 43 4B 52 5A 56 41 4B 51 55 41  PZMSHGCKRZVAKQUA
000002E0  00 20 20 20 20 20 20 20 20 20 20 20 20 20 31 30  .             10
000002F0  2D 30 36 2D 32 30 30 38 00 00 00 00 00 00 00 00  -06-2008........
00000300  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01  ................
00000310  07 00 24 00 16 00 20 00 17 00 14 00 00 00 00 00  ..$... .........
00000320  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000330  00 00 53 00 1C 00 00 00 00 00 00 00 00 00 00 00  ..S.............
00000340  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000350  00 00 08 40 01 00 00 01 30 00 00 05 00 64 00 14  ...@....0....d..
00000360  20 32 00 00 00 0F 00 01 02 00 00 01 78 00 32 00   2..........x.2.
00000370  20 00 55 FF 00 01 00 00 00 00 00 00 00 00 00 00   .Uÿ............
00000380  00 00 00 00 00 00 00 00 00 00 00 00 00 00 58 58  ..............XX
00000390  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000003A0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000003B0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 01 01  XXXXXXXXXXXXXX..
000003C0  01 01 01 00 00 00 00 00 00 00 00 00 00 01 FF FF  ..............ÿÿ
000003D0  FF FF FF FF FF FF 00 00 00 00 00 00 00 00 80 00  ÿÿÿÿÿÿ........€.
000003E0  00 00 00 00 00 01 02 05 10 27 00 00 88 13 00 00  .........'..ˆ...
000003F0  00 00 D0 07 00 00 88 13 00 00 1E 00 00 00 05 D6  ..Ð...ˆ........Ö
00000400  06 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000410  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000420  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000430  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000440  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000450  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000460  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000470  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000480  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000490  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000004A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000004B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
PostPosted: July 4th, 2011, 6:38
help with my WD 3200BEVT-22ZCTO I have try every thing and I couldn't know the password here is the 21.bin file&22.bin
help me find the password it's master password
bin files.rar [751 Bytes]
Downloaded 2157 times
PostPosted: July 5th, 2011, 5:06
Hi Friends...
I have forgot my password. Kindly help me to unlock "My Passport" western Digital 1TB.
P/N: WDBACX0010BSL - 00
S/N: WXG1E21DNN89.
Or else if i format is there any software which will retrieve 100% of the data
thanks in advance
Rajesh
rajeshramawgl@gmail.com
PostPosted: July 5th, 2011, 21:03
See unlock-book-essential-t19408-20.html
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 83 guests
