 Post subject: Seagate ST3250310NS Fw.HPG2 F3 family Lock Led problem
PostPosted: May 16th, 2011, 8:02
I to all.
I have a very strange problem with this drive.
I power on it and i cannot ear any knock, but the hdd stay in BSY status
Running utility, that say me the drive have Lock Led problem
I try to run first solution for Lock Led, with short circuit the correct PCB point, but in this case the terminal show me some F3> prompt and after i see LED error again. In this way the status remain in BUSY and i cannot go on with the solution. I try more time and i have the same result :(
After that i try to run solution using motor isolation, but the solution end with Terminal error. :(
The last try is to download the new seagate firmware from seagate site, but when i run it the upgrade say me "No SATA drive founs" and i cannot update teh firmware. :(
Please some one can tell me how i can do to solve this lock led problem ? :roll:
Thank you to all.
 Post subject: Re: Seagate ST3250310NS Fw.HPG2 F3 family Lock Led problem
PostPosted: May 16th, 2011, 9:21
If you short circuit the PCB while booting the drive, you can reach T> and run commands ?
PostPosted: May 16th, 2011, 9:30
I try it but i cannot reach F3> prompt. I see always LEDxxxxx error repeated each 20/30 sec
PostPosted: May 16th, 2011, 10:12
I've done a few of those, so I think it can be done, but something is wrong with the normal solution.
PostPosted: May 16th, 2011, 12:01
It's usually down to timing with the short points.
Try applying power, wait 2-3 seconds then apply short. With the HDA connected to the PCB.
PostPosted: May 17th, 2011, 4:14
I try that, but i can see F3> prompt, repeated for more time, for some second and after i see again LEDxxxx error and hdd stay on BSY. In that mode i cannot sent any terminal command. If i wait, i can see, each 20/30 sec, another LEDxxxx error reported. I try to press CTRL-Z between LEDxxxx error and another LEDxxxx error, but i cannot have F3> prompt. I suppose terminal is locked but i cannot unlock it. :(
PostPosted: May 17th, 2011, 5:31
pcimage is right have to wait for a while then short, but make sure ur shorting the proper points the motor should stop (kind of hang when shorting)
also try to disconnect the PCB from the hdd, and power on with terminal OPEN (terminal open before powering on) then see the LOG and post results here
PostPosted: May 17th, 2011, 5:46
I have found the point on Pc3K manual. Please can you show me what are the correct point. I want to verify with the poini i use
Thank you
PostPosted: May 17th, 2011, 6:39
I try to disconnect PCB from Hdd and, with Terminal opened, i run utility. I see follow :
PostPosted: May 17th, 2011, 6:41
Sorry that is wrong image. Follow that correct ...... Sorry :shock:
PostPosted: May 17th, 2011, 9:10
I think your drive might have heads issues, not only FW problem.
PostPosted: May 17th, 2011, 9:18
Can Try:
read carefully and figure out:
Standby, and DE, remove some un-necessary options and proceed.
if u need some data from it
good luck
PostPosted: May 17th, 2011, 9:29
I solved my case :D
The problem was probably on firmware version. This Hdd is HP custom with HPG2 firmware. Using the standard technique like short cut pin, it doesn't function.
I make a new try. I start Lock Led solution, but instead to short cut write channel, i inject interference signal (Square wave with appropriate amplitude) on write channel.
In that way, terminal unlock immediatly and i can finish the Lock Led solution.
Now i can read all data.
Thank you to all for help.
Bye
PostPosted: May 17th, 2011, 9:37
Ok.
Congratulations!
PostPosted: May 17th, 2011, 17:46
Hei that whas a very interessant and original trick to sblock the terminal..
compliments!
Italian Recovery - Italian Data Recovery Company
http://www.italianrecovery.it
PostPosted: January 20th, 2012, 19:34
Hi Powermax,
i´m from germany and i have the same issue with the same drivetyp that you´ve discribed here,
Seagate ST3250310NS, is there a chance for me to get help from you?
Greetings Frank
PostPosted: January 26th, 2012, 4:10
Sent to me your MSN ID, and i try to help you.
Bye
PostPosted: February 3rd, 2012, 5:57
Powermax wrote:
I solved my case :D
Bye
Where is write channels located?...I have one ST3750330NS ES2 with HPG1 Firmware, and cant get past terminal lock..
PostPosted: February 5th, 2012, 15:56
Bye
because me account is to fresh i can´t send a private message to you...
here is my msn-id
parcifal98@hotmail.com
greets frank
PostPosted: June 17th, 2013, 12:44
Powermax wrote:
I solved my case :D
Bye
Hi PowerMax.
Success with your Square wave way.
