 Post subject: trying to recover a wd500bevt
PostPosted: May 27th, 2011, 5:04
hello,
i have the following hard drive:
WD500BEVT-00A03T0
WWN:50014EE202BC2D97
from the 27 4 2009
DCM: EHCVJBBB
LBA: 976773168
R/N 701609
PCB:
2060-701609-000 REV P1 (on board)
2061-701609-800 03P (on sticker)
the drive is completely dead and i would like to see if the PCB is the culprit.
i have another drive of the same model albeit from 2011.
i tried the PCB from this one and the drive spins (with some clicking however) up but is not recognized by the computer
now what can i do?
i found a similar drive on ebay with a different WWN (50014EE2AD9792EE) and a different DCM (HHCVJBBB)
but with the same R/N and MDL
do i have a chance that i can use this PCB?
what else can i try before i send the drive to a (costly) recovery center?
thanks for all help!
 Post subject: Re: trying to recover a wd500bevt
PostPosted: May 27th, 2011, 5:35
You should send it....
This drive have unique adaptives inside the PCB, you can't use another drive's pcb on this model.
Janos
PostPosted: May 27th, 2011, 6:27
Is there an 8-pin chip at location U12?
PostPosted: May 27th, 2011, 7:13
no,
U12 is empty
thanks
PostPosted: May 27th, 2011, 7:22
Then the adaptive information is stored in the main controller chip, and needs to be transferred with professional equipment.
Data Recovery Cape Town
PostPosted: May 27th, 2011, 7:25
is this an expensive procedure?
PostPosted: May 28th, 2011, 4:51
Could you upload a detailed photo or scan of the component side of the board? If you're lucky, there may be a simple DIY fix.
PostPosted: May 30th, 2011, 6:06
shure, here it is
PostPosted: May 30th, 2011, 6:39
I can't see any obvious problems. :-(
If you have a digital multimeter (US$10), then we could measure a few voltages. We could start with your good board and establish some test points. It may only turn out to be a post mortem exercise, but it may help others.
PostPosted: May 30th, 2011, 12:26
i do have a multimeter. shoot!
PostPosted: May 30th, 2011, 18:01
Could you measure the voltages at each of the following test points and components on your spare board?
http://www.users.on.net/~fzabkar/HDD/WD ... mp_VCM.jpg
http://www.users.on.net/~fzabkar/HDD/WD ... 12_Vio.jpg
http://www.users.on.net/~fzabkar/HDD/WD ... re_Vio.jpg
Also measure the voltages at the jumper pins.
Use the SATA power ground as your reference:
http://pinouts.ru/Power/sata-power_pinout.shtml
Set your meter on the 10VDC range. Be careful not to slip with your probes, as serious damage will result.
PostPosted: June 1st, 2011, 5:31
hmm, i just realized you want me to measure my good board.
however, since it seems impossible to simply excahnge the boards, i did not get a good one ...
PostPosted: June 2nd, 2011, 5:29
Well, do the same with your bad board.
PostPosted: January 26th, 2014, 14:40
what are the voltages supposed to be
PostPosted: January 26th, 2014, 14:43
hi blofeld i have send a pm to u check please for solution :)
PostPosted: January 27th, 2014, 11:09
Hi Blofeld,
I strongly recommend against experimenting on the board hoping to fix it. If your data is important, you really should have a professional rebuild a circuit board for you. You'll need a PC-3000 to do it, which costs ~$10,000 USD. If you mess the board up too bad while experimenting, it may actually become impossible to recover the data.
I normally charge $500~$650 (plus parts) for this type of recovery in my lab based in Providence, RI USA, but if you just want a rebuilt board and not the imaging onto a new drive, etc. I can probably do it for $350 plus parts. Other labs should have similar prices. If you're outside the USA and would like a recommendation of a company to use, let me know.
Jared
PostPosted: January 27th, 2014, 13:42
US$50, including firmware transfer:
http://www.onepcbsolution.com/
http://www.hdd-parts.com/
PostPosted: January 27th, 2014, 15:41
Yep, that's the problem with donor drive suppliers. They buy pc-3000 just to do a million rom transfers. But, most people aren't willing to risk trying to recover data themselves. So they still hire a professional.
PostPosted: January 27th, 2014, 17:09
@data-medics, you don't need PC$10K to do a ROM transfer.
To Spildit, as much as I like you, and as much as I am grateful to you, you must understand that the world doesn't owe anyone a living. My mission is the same today as it was 20 years ago when I first started posting to Internet forums, and that is to help people as much as I possibly can. If that conflicts with other people's commercial interests, then that is a fact of life that they will have to accept. When I went into business, I did so with the same understanding, and I still managed to earn a respectable living.
Users browsing this forum: michael chiklis and 166 guests
