 Post subject: Needed Maxtor Loader
PostPosted: June 1st, 2011, 11:46
Guys anyone has the loader for this drive:
MODEL: 6B300S006
SN: B61NA3BH
CODE: BANC1E00
thank you
 Post subject: Re: Needed Maxtor Loader
PostPosted: June 2nd, 2011, 4:45
none of u guys have the loader?
:shock: :shock:
PostPosted: June 2nd, 2011, 5:19
You typed model wrong probably
With this f/w version I have seen only MaxLine 3 7VxxxF0, 7LxxxS0 and 7LxxxR0
DataRecovery.bg
PostPosted: June 2nd, 2011, 5:35
here is it
am sure
PostPosted: June 2nd, 2011, 6:02
Well I have found one firmware update for sabre which is exactly BANC1E00 and taking in mind sn all fit for this family.
The loader inside is upside down, and I do not have time to fix it now, if you know the structure of the loader it is 10 min of work. PM if you need help.
This one you have to edit, other are only to see if they will work
7F49_sabre.rar [231.91 KiB]
Downloaded 226 times
2485_7L250S0.RAR [214.1 KiB]
Downloaded 212 times
File comment: You have to edit this loader, since it is upside down inside
banc1e00.rar [272.96 KiB]
Downloaded 215 times
DataRecovery.bg
PostPosted: June 2nd, 2011, 6:10
Many thnx Samo, do not worry, i can handle this
and again 200000 thnx :roll:
Users browsing this forum: ad1479 and 64 guests
