 Post subject: .pst 0 bytes
PostPosted: May 30th, 2011, 8:05
nobody had to recover a pst file of 5 gb that now is 0 bytes?
info:
-EXT2 from an external nas.
-2 different pc by outlook connect to the same file :shock: ( of course one had to close beforer the second pc could connect )
 Post subject: Re: .pst 0 bytes
PostPosted: June 2nd, 2011, 9:33
Try Carving with PhotoRec or try to see if you can undelete it with testdisk , but be sure to use a write blocking method... your mileage will vary. those a re easy enough suggestions without getting to intricate in the recovery,
PostPosted: June 2nd, 2011, 9:45
Are you sure you dont need to take owership of the file?
If your not the owner it would show up as 0 bytes.
PostPosted: June 2nd, 2011, 10:00
It could be that the file got truncated.
If after a scan with a software the result is the same then the problem is serious.
PostPosted: June 2nd, 2011, 10:54
Is there any data in the file when looking at it in hexedit?
PostPosted: June 2nd, 2011, 11:18
File header for example.
PostPosted: June 4th, 2011, 13:17
well,after r-studio scan i found only 1 file 1,9gb corrupted. fixed with a software, it was recovered to 1,5 GB
still missing a lot of emails!
r-studio found a lot of files without extension.
i recovered all from 5 to 6 gb. opened by winhex i found few header inside of them, typical of pst files (!BDN).
but my software to recover pst files, was not able to fix any of them :(
do you think i followed the right way?
PostPosted: June 4th, 2011, 13:18
no data inside, size 0 bytes was correct.
no header in that file.
Users browsing this forum: No registered users and 117 guests
