 Post subject: Best Program for cloning drives
PostPosted: June 6th, 2011, 18:38
hello can anyone recommend a good program that can do a perfect clone of a hard drive.
i been using nortons ghost but is there anymore that better
would like it to handle fat32 and also ntfs
 Post subject: Re: Best Program for cloning drives
PostPosted: June 6th, 2011, 20:20
EASEUS Todo Backup Home 2.5 has worked perfectly for me.
PostPosted: June 6th, 2011, 20:23
hi thanks for that do you know any others that i can run from cd in dos
PostPosted: June 7th, 2011, 17:49
Hi
Easeus Disk Copy (http://www.easeus.com/disk-copy/feature.htm) can boot from a CD and clone HD's. Works very well. Sometimes, I use it.
ACELab partner
PostPosted: June 8th, 2011, 2:57
If you look for software with good specification and DOS version than you need to try Media Tools Pro.
Or try Hirens Boot CD there is a few clone/ imaging programs.
Norton ghost is not bad for good drives, it's possible to make sector by sector image, than that image need to be converted to dd image so can be used with recovery software.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: June 8th, 2011, 4:40
R-Drive Image can clone/image a disk/drive. "Understands" many non-Windows disk partition layouts and can copy either the entire disk or only areas acutal data occupies. Creates either exact byte-to-byte or compressed images, R-Studio can work with the latter. It has a full-featured Linux-based startup version.
R-Drive Image.
R-Studio has an excellent object cloning/imaging module. There is only one issue: the startup version of corporate R-Studio is locked to one computer. More expensive R-Studio Technician doesn't have this problem.
R-Studio.
R-Studio Data Recovery Software
Users browsing this forum: No registered users and 67 guests
