Forum rules
 Post subject: External Flash Rom-Pin Damaged
PostPosted: June 15th, 2011, 10:19
While desoldering External Flash ROM there is one pin got damaged, anybody help in this case how to recover the data from that hard disk without Original Flash ROM
MODEL:-ST9320325AS
FIRMWARE:-0002BSM1
 Post subject: Re: External Flash Rom-Pin Damaged
PostPosted: June 15th, 2011, 13:00
It's F3 architecture, so very very difficult indeed :-(
PostPosted: June 15th, 2011, 14:07
thank you very much for your quick reply
PostPosted: June 15th, 2011, 16:36
Can you post a picture of the damaged rom?
Murphy was an optimist
PostPosted: June 16th, 2011, 3:00
Not all pins need to be present in order to read the flash memory.
PostPosted: June 16th, 2011, 8:50
In case the missing pin is a mandatory one:
I have seen emergency repairs been done by replacing a missing pin with fine gauge wire wrap wire. Takes good eye sight and a steady hand while soldering. Probably works best for pins at the end of a row. In case a tiny piece of plastic has to be milled away.
Have to admit I never used that technique myself. I would have started out by trying to read the chip with an Eprom programmer... probably sacrificing the test clip while attempting to get a connection to the missing pin.
PostPosted: June 16th, 2011, 15:26
I did this allready with good success. Microscope is neccessary.
Dobre
PostPosted: June 22nd, 2011, 6:16
I had to do this last week, one leg of the ROM chip snapped off when removing it from patient PCB. I transferred it to donor PCB and had to fiddle for about an hour to build up my own 'leg'. I actually used a leg off an old ROM chip I had lying around, worked well.
Data Recovery Cape Town
