Forum rules
 Post subject: HPA and DCO
PostPosted: June 16th, 2011, 11:36
I currently working on hard disk and having some troubles conserning them. i got some machines which are lock on for certain types of hard disks and since they are no longer manufactured i must find a way through. So i had been looking for different ways in solving the problem.
The current software have been locked on the hard disk capacity and its name. I successfully found a way to edit the size of a hard disk through the DCO (Device configuration overlay) but i still can't find a wayto change the name of the hard disk. Any of you guys can help me to find a software which i can use to modify the name of the hard disk.
FUJITSU MHZ2500BT  ==> Maxtor something
 Post subject: Re: HPA and DCO
PostPosted: June 16th, 2011, 12:08
There is no free solution
PostPosted: June 20th, 2011, 4:29
What are the paid solutions then?
PostPosted: June 20th, 2011, 10:24
If you want to do it yourself then there are at least three commercial tools
PC3000, HRT and Salvation Data Tools
Or you can find somebody with tools and pay him/her for the job
PostPosted: June 21st, 2011, 6:10
Have you tried the obvious alternative approach, ie have you looked for a "Maxtor something" text string in your software, and then attempted to edit that?
Do you have a chip reader/programmer that can read serial EEPROMs?
PostPosted: June 21st, 2011, 9:36
Just to save you on this effort
1. Fujitsu store model information on platters
2. Modifying ROM w/o recalculating CS is a very bad idea
3. Not all MHZs have external flash
PostPosted: June 21st, 2011, 20:31
1. If a drive PUIS (that's DR-speak for "Powers Up In Standby"), then any Identify Device report must use the data on the PCB. How does a drive identify itself in such cases?
2. I did not suggest that the OP modify the "ROM" without recalculating the CS (I assume "CS" is DR-speak for "checksum"). In fact there have been several threads where I have had to explain to data recovery professionals why a drive will not spin up if its CheckSum is bad.
3. I don't believe the OP is restricting his choice of replacement drives to a particular model. I suspect that he would be prepared to accept any drive that could be made to appear like a "Maxtor something".
PostPosted: June 21st, 2011, 20:40
It does not
Many drives in PUIS mode return almost empty ID sector
FYI PUIS is an acronym from ATA standard, so it's not DR-speak (neither the CS). Of course we can continue on this and pretend that WA is Australian-speak for Western Australia :)
PostPosted: June 21st, 2011, 20:43
Sure
Assuming that neither you nor topicstarter don't know how to do that finding programmer seems a little useless to me
PostPosted: June 25th, 2011, 7:08
Sure
Well, I'd have to see it before I could attempt it. If it's just a straight sum of bytes or words, then it shouldn't be too difficult. I know that some checksums (eg Samsung firmware) are byte-swapped, but that's easy to handle as well. If it's anything else, then I'll cross that bridge if and when I come to it. In any case, I should be offended by your assumption, but I'll let it go.
PostPosted: June 25th, 2011, 15:47
Many companies still sell 2.5" Maxtor's. PM me and I can point you in the right direction
PostPosted: June 26th, 2011, 2:44
@miky , How many of them you want, or how many 2,5" do you want , with what LBA count or capacity and what model? PM me.
PostPosted: August 22nd, 2011, 12:08
Model disk's names can be edited within the service area and the size of the hard disk CAN be edited by setting the Max LBA or CHS depending on the hard disk being used..
PostPosted: August 23rd, 2011, 3:05
@miky, I'm from france and have a PC3000. PM me if needed.
Lemmy
Users browsing this forum: No registered users and 85 guests
