 Post subject: Boot Sector Rebuild
PostPosted: June 24th, 2011, 13:25
Hi guys,
I have a toshiba 640Gbs External Drive. Recently it has been corrupted and changed file system from NTFS to RAW, even after using a couple fixes the drive isn't working, so i ran a couple more diagnostic softwares...and i found a damaged boot sector and backup bootsector.
So i have to rebuild the boot sector on the drive to fix it...thing is....its takes a lot of time using TestDisk 6.13
Does anyone know a quicker way to fix this problem?
 Post subject: Re: Boot Sector Rebuild
PostPosted: June 24th, 2011, 13:49
What's wrong with your existing boot sectors?
PostPosted: June 24th, 2011, 14:14
Here is a screenshot of testdisk:
PostPosted: June 24th, 2011, 14:20
It would be helpful to know if the sectors are present but garbled, or completely unreadable, or what
PostPosted: June 24th, 2011, 15:15
They are unreadable...
at first i could list the files on the disk and copy them using a raw copy software....but i cant even do that anymore...
PostPosted: June 24th, 2011, 15:16
Trying the rebuild option....but its been 2 days...and its still at 200.000.000 of 1.250 mils sectors... xD
PostPosted: June 24th, 2011, 15:34
http://www.dtidata.com/resourcecenter/2 ... ion-drive/
This shows you how to use winhex to manually create the mbr Using there templates. Info in the mbr template for sector 0 needed changing to the following for me
Start heads 32, start sector 33 & Start cylinder 0
My ntfs lba was 2048
Also make sure at the end of sector 0 & your ntfs sector it has 55AA
PostPosted: June 24th, 2011, 15:54
If your drive is developing bad sectors you should be cloning it rather than running software scans or doing anything that will write to it
Users browsing this forum: Google [Bot], WebClaw and 78 guests
