 Post subject: WD800JD-60LSA0 need head alignment
PostPosted: July 4th, 2011, 9:56
Hi
Western Digital WD800JD-60LSA0 need head alignment if i changed head?
Thank u
 Post subject: Re: WD800JD-60LSA0 need head alignment
PostPosted: July 4th, 2011, 10:08
In my experience typically no, but these drives are a pain to recover data from. They may need a little playing around with. Also, for me, these drives often have a lot of damage as far as bad sectors, even in the SA. Frequently, the only way to recover is via hot swap.
PostPosted: July 4th, 2011, 10:42
Probably some alignment will be required.
http://www.datasaversllc.com
PostPosted: July 8th, 2011, 2:34
Jono-ats is right. In my opinion all WD which secure the HSA through the screw in the top cover will need some alighnment.
Users browsing this forum: Google [Bot] and 58 guests
