 Post subject: WD1200BB-00DAA3 Unknown issue
PostPosted: July 4th, 2011, 10:38
Hi
I have a WD1200BB-00DAA3 that first he just made the heads clicking noises..
With a drive form the same family I was able to make a hotswap and save all the modules and SA tracks.
After that I connect the donor drive and copy the A and AS modules from the original drive. I made the hotswap again and this time I was able to read the sector 0. I open a task in data extractor but each time I tried to read other sector the drive stops reading. I tried a couple of times but all the times I was just able to read the sector 0.
What I did next was connect the donor drive again and copy all the B modules but when I power off/power on the drive never detect again.
Because I didn´t have other drive from this family to repair the one that gets damaged I replace the heads. After I replace the heads I was able to recognize the drive and create a task in data extractor but I have kind of the same problem again, I was just able to read the first sector.
Anyone already got a issue like this?
Do you guys have some suggestions?
 Post subject: Re: WD1200BB-00DAA3 Unknown issue
PostPosted: July 4th, 2011, 10:46
What does the DE task log say as far as errors? Also, what settings do you have in place for reading error and losing readiness tabs?
PostPosted: July 5th, 2011, 7:53
Hi
In the DE task the drive just tried to do a soft reset when I try to read any area and after that never detect again, the drive try to reestablish the ready state but ends to power off the drive.
Know I´m getting a different symptom, now each time I power on the drive, he recognize the ID but give me this error:
https://rapidshare.com/files/641987152/ ... _16.52.gif
After this I don´t know what to do. If I heaved other hard drive from the same family I wold do a hotswap.
Any idea what I can try now?
