 Post subject: how do you manage this
PostPosted: July 9th, 2011, 15:45
got a drive that was opened by other DR company.
usually when i find digital marks on plates i do not clean them becouse often the cleaning can bring more issues.
how do you judge this cropped photos?
 Post subject: Re: how do you manage this
PostPosted: July 10th, 2011, 3:52
u cannot judge unless you clean this mess and try it your self
i had many similar cases but were done, if you were lucky its OK
try it
PostPosted: July 10th, 2011, 4:13
PM sent :wink:
PostPosted: July 10th, 2011, 5:40
Is that a bent head as well???.... :shock:
http://www.eadr.co.uk
PostPosted: July 10th, 2011, 5:48
i magnified the picture, you looked good: bend head # 3 and crash head#2 , i can't see very well other heads... but that's enough!
the strange is that the drive goes in ready state! but not ID's
PostPosted: July 10th, 2011, 6:25
The strange is that you have powered up in this condition...
BTW this drive can be recoverable in the good hands.
I don't really like similar cases because have too many in. :D
but i can help if you really want....
Janos
PostPosted: July 10th, 2011, 6:29
Janos
i forgot to tell you that the label didn't show any sign of opening, the other DR company simply copy the original label with a scanner and stick the new label on the drive.
never happen to me before.
PostPosted: July 10th, 2011, 8:25
In that case why not name and shame the company which had it before you? :x
PostPosted: July 10th, 2011, 20:26
To return a drive in this condition with this sort of failure is unthinkable.
(unless the client treated them really, really, really bad ... but even that is stretching it)
Damaged Heads remounted (if they even attempted to replace)
Bent Head
Fingerprints on platters
I would like to know the company so i could avoid them at all costs...
Why wouldn't they snip the heads off or remove the HSA completely since its toast?
PostPosted: July 11th, 2011, 2:55
Out of curiosity, was the drive SENT BACK from the DR company as "UNRECOVERABLE" because it was originally sent in this condition, or the condition depicted is consequence of work of the "DR" company ?
(probably we'll never know...)
Anyway, the fingerprints can be eliminated and surface decontaminated, but there's little to do about the scratches ... Maybe if the underlying surfaces are good , a partial recovery is still possible. Maybe 8)
PostPosted: July 11th, 2011, 3:05
einstein9 wrote:
PM sent :wink:
arrived well, thank you !
PostPosted: July 11th, 2011, 3:38
The drive was sent back as "unrecoverable" but also like "NOT opened".
PostPosted: July 11th, 2011, 4:20
Head 2 looks really mashed up. I'm surprised that the HSA even gets back onto the ramp in that state? I'm sure that head would have scratched it's side of the platter pretty badly, maybe contaminating the surface below, unlucky that is was powered on in that condition! I would hate to see the underside of that top platter. Head 0's surface is probably the only one that's in a half decent condition. I had a similar case last month, Hitachi 2.5" 4 platter with fingerprints all over the top platter. Cleaned it up and imaged the entire drive after HSA swap with only a few errors on that top surface. There's wasn't much contamination though, just fingerprints and the odd speck of dust.
Good luck.
Data Recovery Cape Town
PostPosted: July 11th, 2011, 4:30
Good luck.
even this is hitachi 2,5''. the firs set of HSA i have in laboratory.
Now i am thinking if check the underside of the top platter (but loose the platter alignement)
or give it a try just cleaning the top surface..
PostPosted: July 11th, 2011, 4:32
If you have changed heads already for new set did you modify NVRAM to allow access with H0 only? To check if you can at least read SA from surface with new HSA?
PostPosted: July 11th, 2011, 18:39
Hi i saw some pencil signs, and i decided to have a look at the internal surface of the platters.
i post the photos
File comment: internal of platters (heads 1 and 2)
File comment: pencil marks..
PostPosted: July 11th, 2011, 18:43
I think, based off the second set of photos, it is dead. =)
PostPosted: July 12th, 2011, 6:35
I think it is (almost) dead. :)
What type of documents what do you need from this .... drive? :D
Maybe i still can help...
Janos
PostPosted: July 12th, 2011, 6:38
btw, pencil signs:
Hitachi usually have some pencil marks on the edge of the platter, but you break the alignment if you remove one platter only...
Wich model it is exactly?
Janos
PostPosted: July 13th, 2011, 15:38
N.C. wrote:
btw, pencil signs:
Janos
hi i made alignment reference in another place. you really want to try to recover this drive? pm me..
Users browsing this forum: michael chiklis and 58 guests
