 Post subject: Dead WD200 20GB
PostPosted: July 15th, 2011, 11:27
Wont fire up, PCB is getting hot
TVS?
ta
Andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Dead WD200 20GB
PostPosted: July 15th, 2011, 12:55
Doubt it. New PCB + U12 swap.
Data Recovery Ireland
PostPosted: July 15th, 2011, 13:20
If the little components BENEATH the motor IC are too hot to touch, then it probably has a bad preamp, too.
The motor IC will get pretty warm normally.
http://www.datasaversllc.com
PostPosted: July 15th, 2011, 13:57
What model exactly?
PostPosted: July 16th, 2011, 4:43
TVS?
ta
Andy
A shorted TVS diode will shut down the power supply, therefore nothing will get hot.
PostPosted: July 16th, 2011, 5:33
Helpful, thanks guys
this one sean ;)
andy
PostPosted: August 1st, 2011, 5:01
The donor I have is Same MDL but the DCM is DSBHET2CH
Would this donor suffice provided the U12 is swapped ?
thanks
PostPosted: August 1st, 2011, 5:13
You will need to check the PCB part number and see if they match.
PostPosted: August 1st, 2011, 5:15
thanks
PostPosted: August 1st, 2011, 5:19
Yes, this will be ok,
PostPosted: August 1st, 2011, 5:32
hddguy, cheers
Users browsing this forum: No registered users and 175 guests
