 Post subject: Maxtor 4D040H2 PCB dead, eeprom transfer
PostPosted: July 15th, 2011, 13:33
Hey all,
Can someone please help me identify the eeprom(s) from this PCB that I would need to transfer onto a donor?
Thanks!
 Post subject: Re: Maxtor 4D040H2 PCB dead, eeprom transfer
PostPosted: July 15th, 2011, 13:59
There isn't one.
What's up with the drive?
PostPosted: July 15th, 2011, 19:58
I got the drive to power on; before it would not do this. So, the activity light flashes during i/o, but the heads are definitely not moving as all I hear is just the whirring of the motor. No other unusual noises. Thoughts?
//edit -- the drive is recognized within windows, but any i/o operation fails
PostPosted: July 15th, 2011, 20:54
Get the mhdd software and run it on the drive to see if it detect correctly. The software is available here on the forum. Just search for it, read the manual before doing anything.
PostPosted: July 15th, 2011, 22:14
Just Tried mhdd. The drive is recognized properly, but cannot be read. Smart variables seem normal, but scan fails. Seek & read also fails. The spin up and spin down commands do work. When the drive spins up I can hear the head move into position and that's the only movement that it makes.
PostPosted: July 15th, 2011, 22:38
Is it clicking?
PostPosted: July 16th, 2011, 2:27
Post picture of mhdd while scanning the drive with F4 option.
PostPosted: July 16th, 2011, 6:40
50/50 firmware / HSA
PostPosted: July 16th, 2011, 10:20
It is not clicking. If firmware, what are my options?
PostPosted: July 16th, 2011, 11:04
Repair the firmware. Simple.
You need in this order:
1) HW diagnostics
2) Know how 4D work.
With appropriate diagnose you can sort out if it is a head problem.
PostPosted: July 16th, 2011, 11:48
For HW diagnostics, do you mean clean room diagnostics on the HSA? Is there something about 4D specifically I should know? Can I flash new firmware or borrow the firmware from the donor?
PostPosted: July 16th, 2011, 15:34
He means you will have to use special tools and the cheapest you can go for is salvation data for maxtor .
PostPosted: July 17th, 2011, 18:02
Your drive have SA problem (Firmware) and you can't get another one, because all are unique, you need to repair the original.
For this, you will need professional gear, wich is more expensive than a simple recovery by any company.
If you need your data, and don't want to spend 10000$+ on, seek for professional help, this drive should be recovered cheap.
If you will get too much price, write here, maybe someone can help near you from this forum...
Janos
Users browsing this forum: No registered users and 55 guests
