Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Problems with seagate 750GB 2.5inch sata hdd
PostPosted: July 7th, 2011, 5:31
Have not seen that thread pclab but I will read over it when I am off from work and ready to build the adapter to talk to the drive's firmware. I fully plan on trying a spare drive first.
Thanks!
PostPosted: July 19th, 2011, 4:29
I now have the USB to rs232 TTL adapter.
[power][data]{ T R x x }
For SATA
Means all I need to do is wire up the adapter Tx, Rx, and GND to the drive then move onto the PC settings and commands!
From soldering-required-232-seagate-terminal-parts-list-t10218.html
PostPosted: July 19th, 2011, 5:46
Same caveat applies :
1) wrong command - even a single letter - will make your drive FUBAR (if it's already not FUBAR) in a flash.
2) you need to know what to do and what the problem is. And this is the most difficult part :mrgreen:
So said, happy experimenting.
PostPosted: July 19th, 2011, 15:57
Thank you, yes these points have been made before and are well understood.
So, I ask, are there any good places to start? I've got a Seagate 60gb 2.5 inch SATA drive I will practice on.
Users browsing this forum: No registered users and 274 guests
