 Post subject: Samsung HS080HR
PostPosted: July 29th, 2011, 5:21
i requested for a donor drive at the hard drive market of this Samsung HS080HR 1,8''.
the characteristics of the patient drive are:
Model: HS080HR
2008.06
SEC-HS080HR(B)
i found a donor drive with the following characteristics:
Model: HS080HR
2008.10
SEC-HS080HR(B)
will it be compatible for a head change?
thank you in advance
 Post subject: Re: Samsung HS080HR
PostPosted: July 29th, 2011, 10:12
Should be
PostPosted: July 29th, 2011, 11:41
Yes it should be fine
PostPosted: July 31st, 2011, 13:52
thank you. i will let you know if everything went ok
Users browsing this forum: Majestic-12 [Bot] and 141 guests
