 Post subject: Loader needed WD1600BEVT-75A23T0
PostPosted: August 1st, 2011, 6:58
I would need a loader for this disk WD1600BEVT-75A23T0.
If someone could help...
Lemmy
 Post subject: Re: Loader needed WD1600BEVT-75A23T0
PostPosted: August 1st, 2011, 11:18
I can give you a Loader, but probably wont be compatible.
What SA revision you need?
PostPosted: August 2nd, 2011, 5:51
Hello
What do you mean by "What SA revision you need?". I think I only need module 11 for now.
Lemmy
PostPosted: August 2nd, 2011, 6:26
Using incompatible LDR will not allow HDD access
Uploading an incompatible Overlay to the patient SA will cause serious problems.
For both instances, you need to know exactly what version of this module you need.
PostPosted: August 2nd, 2011, 6:54
Ok
First, thank for trying to help me.
I'm sorry for this question but how can I know th exact version of the module ?
Lemmy
PostPosted: August 2nd, 2011, 7:04
You use PC3000? or SD?
PostPosted: August 2nd, 2011, 7:10
I have PC3000.
It told me that LDR loading is recommended !
Lemmy
PostPosted: August 2nd, 2011, 7:39
When you open WD utility with HDD attached the log should show you your ROM version, this will be enough to identify the SA version needed.
What symptoms does your case show?
PostPosted: August 2nd, 2011, 8:20
ROM version is 14.36Q
Everything seems to works fine but disk is not recognised...
Lemmy
PostPosted: August 2nd, 2011, 10:16
Here is the #11.rpm.
I have the entire resources but am having problems uploading here....
11.zip [177.64 KiB]
Downloaded 457 times
PostPosted: August 2nd, 2011, 12:55
Thanks a lot.
I'll try tomorow morning.
Lemmy
Users browsing this forum: No registered users and 14 guests
