 Post subject: Seagate Compatibility Question
PostPosted: August 9th, 2011, 7:11
Have a burnt seagate
Donor is from same model but some chips are different manufacturer
Looking to swap the boards and the highlighted ROM chips
Will this be a match?
Many thanks
andy
DRIVE
Client Board + Highlighted chips
Client
Donor
Donor Back
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: Seagate Compatibility Question
PostPosted: August 9th, 2011, 7:20
There is usually only one ROM chip. I think this is the one in the upper left corner.
You can try to swap them and see !
Lemmy
PostPosted: August 9th, 2011, 17:50
Online
Yes it's true.
PostPosted: August 10th, 2011, 6:01
I've had success with using PCB from identical drive, even though controller chip is different (LSI vs ST). ROM chip will most likely start with the numbers '25'
Data Recovery Cape Town
PostPosted: August 10th, 2011, 6:44
Worked
Thanks to all :)
PostPosted: August 10th, 2011, 7:09
Congrats.
Users browsing this forum: Google [Bot] and 207 guests
