 Post subject: HDD DAMAGE
PostPosted: August 18th, 2011, 0:21
MY HITACHI HTS725032A9A364 HARD DRIVE IS NOT WORKING SOME REGENERATOR SOFTWARES SAYS MASTER BOOT RECORD IS DAMAGED HOW TO SOLVE THIS PROBLEM PLEASE HELP
THANXX
 Post subject: Re: HDD DAMAGE
PostPosted: August 18th, 2011, 4:14
Try a logic recovery tool...like get data back or r-studio.
And please don't write all in CAPITAL letters.
Regards Bosse
http://www.rescue-it.se
PostPosted: August 18th, 2011, 5:20
Have you considered that poor choice of software will only complicate things?
What 'regenerator' software do you mean?
Assuming just MBR is bad, data should still be highly accessible. Are other sectors accessible?
You should try R-Studio as suggested, but if MBR is reported bad because the surface cant be accessed then you need to identify the actual fault before doing anything else.
PostPosted: August 18th, 2011, 5:56
if the problem is only MBR then THERE IS NO problem ;)
PostPosted: August 18th, 2011, 10:34
easy fix - you can use cd of XP or diskpatch or google it..
PostPosted: August 18th, 2011, 22:50
If the only problem is the MBR, then you can consider testdisk; however, there's no telling what else is wrong with the drive. And it doesn't seem like you've done this before...
Users browsing this forum: Majestic-12 [Bot] and 154 guests
