 Post subject: unrecognized usb flash drive
PostPosted: August 25th, 2011, 12:17
A customer brought an Ativa 4gb usb flash drive that does not recognize. It attempts to install the driver, but fails on Windows 7 and XP Pro. Linux does not see the drive, so I cannot attempt to mount.
Windows does recognize there is a drive in the usb port, but that's as far as it goes. Device Manager assigns a drive letter, D:, but it says the port is empty.
I have tried Data Extractor and GDB, but neither finds the drive.
R-Studio sees the device generically with the following specs:
Device/Disk: UFDUSB Flash Drive1100
FS: #3 USB(98:232)
Properties:
Drive Type: Physical Drive, Disk
Name: UFDUSB Flash Drive1100
OS Object: \\.\PhysicalDrive3
R-Studio Driver: WinNT\Handle\Physical
Sector Size: 512 Bytes
I/O Tries: Default
Drive Control
Maximum Transfer: 32 KB
I/O Unit: 512 Bytes
Buffer Alignment: 4 KB
Device Identification:
Vendor: UFD
Product: USB Flash Drive
Firmware: 1100
Bus Type: USB
Am I overlooking something logical?
 Post subject: Re: unrecognized usb flash drive
PostPosted: August 25th, 2011, 12:47
All that is being recognized it the usb controller, and not the data chip.
There is probably not much more you can do besides testing the circuit board components , like resistors.
The flash chip will most likely need to come off and read into a flash recovery machine.
If you do not have the appropriate hardware to do this. (PC-3000 SSD edition, or soft- center) then I would outsource it to a DR company that can do that.
Good Luck
PostPosted: August 25th, 2011, 13:46
Cleanroom is correct.
The device appears to have a problem, which will require the chip removing and decoding.
PostPosted: August 26th, 2011, 9:47
Thanks for the replies. Will talk to the client to see if they want to outsource.
Users browsing this forum: No registered users and 142 guests
