 Post subject: Samsung HS080HR 1,8'' 0 bytes
PostPosted: August 23rd, 2011, 6:05
Hi all, i have a Samsung HS080HR 1,8'' which when you plug it with USB its recognised by windows, at administration managment shows its capacity, but its empty 0 bytes. i tried to use R-studio and EASEUS Data Recovery but its not recognised.
when i use Atola or DDI or PC3k it is not recognised at all. is there something wrong with the adapter i use? any suggestions?
thank you in advance
 Post subject: Re: Samsung HS080HR 1,8'' 0 bytes
PostPosted: August 23rd, 2011, 20:00
To rule out a connection set up issue, connect a known working drive with the same interface and see if it works correctly.
PostPosted: August 25th, 2011, 3:06
i have an identical drive which works perfectly. i tried to put it on the PC3K, DDI and Atola but couldn't be recognised. i am thinking of doing a head swap but thats my last option. i don't think it could help
PostPosted: August 25th, 2011, 22:31
If you ran your perfectly working donor on all these tools and it is not recognized, then the connection is not set up correctly.
PostPosted: August 26th, 2011, 3:30
You're not very clear about if your donor is working fine with Atola or PC3K.
PostPosted: August 26th, 2011, 5:01
the donor drive works perfectly when you connected directly to the pc. it is not recognised either at Atola or PC3k. i supose its the connection.
PostPosted: August 26th, 2011, 5:29
Probably you got some wrong connection.
I think you should first get the good working drive to power up fine in PC3K and then start with the patient.
PostPosted: August 26th, 2011, 10:37
yes i think the same thing. but apart from the usual connection with a classic adaptor http://www.ebay.co.uk/itm/ZIF-CE-1-8-ID ... 141wt_1026 i cannot think of anything else. is there any 'special' adaptor for samsung drives?
PostPosted: August 26th, 2011, 11:07
Can you post a picture of the connections here?
PostPosted: August 26th, 2011, 11:40
the drives are identical. thats the way i try to connect the drive with PC3K. ( the second is with the usb connection which works fine). thank you for ur interest
DSC00430.rar [2.14 MiB]
Downloaded 313 times
PostPosted: August 26th, 2011, 11:46
And how do you connect from there to PC3K ?
PostPosted: August 26th, 2011, 11:48
with IDE
PostPosted: August 26th, 2011, 12:02
I don't have any of those here to test, but that's odd.
Have you talked with Ace about it? To know if there's any problem with those.
PostPosted: August 26th, 2011, 12:37
even with DDI and Atola have the same problem
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 107 guests
