 Post subject: Fujitsu MHY2250BH Clicking and in Busy State
PostPosted: June 15th, 2011, 23:29
Hi Guys,
I wonder if you can help me identify the issue with a fujitsu drive I got from a customer. I can’t find anything relevant on forums as these drive are not that common.
It is a : Fujitsu MHY2250BH, CA06889-B30900C1, 0080890B
It makes a clicking noise and when connected to HD doctor it stays on busy state.
I got an exact donor drive which function good and I have done the following:
1. Replaced PCB from donor to patient – still behaves exactly the same.
2. I opened 2 drives in a clean room and noticed the following:
Patient drive – heads looks physically undamaged but they move from side to side of the platters without stopping – in and out – that what makes it cliking.
Donor drive – heads moves from parking area to internal edge of platters and stop there.
What do you think is the problem,
Any help will be good,
Oded
 Post subject: Re: Fujitsu MHY2250BH Clicking and in Busy State
PostPosted: June 16th, 2011, 3:20
Heads bad, and quite possibly media damage. Often is on this series :-(
PostPosted: June 16th, 2011, 7:28
And if it's from Apple even worse :(
PostPosted: August 31st, 2011, 19:10
Just a quick update regarding the result.
Did heads replacement and still had the same problem.
Tried another head replacement and it worked perfectly - imaging the data as we speak.
Cheers,
oded
PostPosted: September 1st, 2011, 3:37
Nice. So means that first head stack wasn't compatible.
Can you post details of all 3 drives?
PostPosted: September 1st, 2011, 4:53
Sure mate, all 3 were the same:
Fujitsu MHY2250BH,
CA06889-B30900C1,
0080890B
PostPosted: September 1st, 2011, 5:25
Can you tell me what chars are crossed, from those start with 0 1 2 ....
PostPosted: September 1st, 2011, 5:58
Sure mate,
I am not at office at the moment, will post it tomorrow.
Cheers,
Oded
PostPosted: September 2nd, 2011, 1:11
HI dmarques
The crossed chars are: 0 and 1
In all three drives.
PostPosted: September 2nd, 2011, 3:28
Ok. Nice to know. Thanks
PostPosted: September 5th, 2011, 16:10
did u try to put back the heads to the donor in the swap #2 to see if they were not compatible or simple demaged in the operation?
Users browsing this forum: Google [Bot] and 149 guests
