 Post subject: samsung HM120JI always busy
PostPosted: September 5th, 2011, 15:50
this Samsung HM120JI stay always busy, it spins, the heads try to calibrate i suppose ( they make many noise like they cant find servo track )
i post the terminal log here, i think can't be heads problem:
 1.5G Limited
SPW 1.5G Link Ok!
IndS=+00004
Spn OK
H: +00000
UF: 1st Gray err
H: +00001
Load
SK C: 0000DFD8
ENG>SRV> AP_FSAM
C: 0000DFD8 H: +00001
UF: 1st Gray err
H: +00001
SK C: 0000DA77
AP_FSAM
C: 000001F4 H: +00000
SR : +00000
UF: 1st Gray err
H: +00001
AP_FSAM
 Post subject: Re: samsung HM120JI always busy
PostPosted: September 5th, 2011, 16:21
Most probably you got H1 damaged.
But of course, needs further checking.
PostPosted: September 5th, 2011, 16:23
Hi David,
to be sure i have just swapped since i had the donor in laboratory: it is not concerned from heads ( on donor they are perfectly working )
uhm firmware issue.. i try also hot swap but didn't work :(
PostPosted: September 5th, 2011, 16:43
Terminal output points to heads most likely. If donor heads are good then maybe media damage?
Data Recovery Cape Town
PostPosted: September 5th, 2011, 17:10
Hi Nikola, yes i suppose media demage in SA, so i wanted to find out a loader or something to put in ram and boot the hdd..
PostPosted: September 5th, 2011, 17:11
Media damage is also odd, if heads are still working fine on donor.
It could be a FW issue, but difficult to understand just like that.
Have you tried to put patient heads on donor drive ?
PostPosted: September 5th, 2011, 17:13
yes, they work like a charme on donor... :( but i am not happy!
PostPosted: September 5th, 2011, 17:14
Have you checked if head map on patient and donor is the same?
PostPosted: September 6th, 2011, 3:32
no i didn't ( you think it matters ?)
PostPosted: September 6th, 2011, 5:06
It could be that the patient heads worked on patient, because one damaged head could not be in use.
PostPosted: September 6th, 2011, 5:10
you mean donor or patient here:
" It could be that the patient heads worked on (patient) " -> donor
PostPosted: September 6th, 2011, 6:06
I mean patient on donor :)
PostPosted: September 15th, 2011, 3:28
yes heads are fully ok (read and write test performed) on donor.
would like to try rom swap but i cant find "25" on any chip..
PostPosted: September 15th, 2011, 3:50
In that case, there's no external ROM, it's within the CPU.
Users browsing this forum: No registered users and 83 guests
