 Post subject: Water Damage Hard Drive, How to clean multiple platter
PostPosted: September 6th, 2011, 13:13
Does anyone know what kind of ionizer/equipment is required to clean flood damage hard drive’s platter ?
 Post subject: Re: Water Damage Hard Drive, How to clean multiple platter
PostPosted: September 6th, 2011, 13:28
Can you post a picture to check the extent of the damage?
PostPosted: September 6th, 2011, 13:37
Platter is not Damaged drive was in water for a very short time.
PostPosted: September 6th, 2011, 13:47
I have used a solution from M3, pretty sure it contains IPA.
What water was it in? Are platters dirty? How much dirt got into the drives?
Also, what drive is it?
PostPosted: September 6th, 2011, 14:41
To be honest (and fair to the person whose data it is) if you don't already know how to do it you should outsource to someone who does
Then go throw some old drives in a puddle for a while and get practicing :)
PostPosted: September 6th, 2011, 14:57
Drive have 3 platters. which is not dirty but do have water marks on it. I can Clean top of the platter but how come I will clean middle or the plater to remove water marks ???
PostPosted: May 17th, 2016, 2:58
Hope you was fixed this problem . If yes ? then what you did ? Please share with me. I am also working on this type of case , Drive fell in water .Thanks
Users browsing this forum: Google [Bot] and 193 guests
