 Post subject: Hitachi HTS725050A9xxx can't read any modules
PostPosted: September 16th, 2011, 13:54
I've got a Hitachi 2.5" 7200 500GB which does not ID at all. Doesn't click, spins up and stays spinning and sounds normal and is DRD and DSC. I tried checking FW modules but PC3K couldn't read any. I though perhaps weak heads so I stuck in a set of good donor heads, but have the same problem.
Test : Start SA checking
Module is not loaded (RESF, Main module table)
NV-RAM reading.......................... : Ok
Module checking
Module RSVD Copy 0...................... : Error
Module RSVD Copy 1...................... : Error
Drive then goes BSY and stays BSY when trying to check modules. Donor heads work fine if they are put back in donor. Can't read any modules, drive doesn't ID...stuck. Any ideas would be welcome. Thanks. A good weekend to all.
Data Recovery Cape Town
 Post subject: Re: Hitachi HTS725050A9xxx can't read any modules
PostPosted: September 16th, 2011, 14:34
I've put patient heads into donor and they work, so heads aren't the issue...
PostPosted: September 16th, 2011, 23:30
I have seen strange things with Hitachi drives. I would try to rule out the PCB next.
PostPosted: September 17th, 2011, 17:27
Yes, you should swap it to be sure it's fine.
PostPosted: September 18th, 2011, 14:44
I found the solution to this one by troubleshooting everything I could :) Bizarre and was the last thing I expected, but have full access to user data now.
PostPosted: September 18th, 2011, 17:20
Good deal congrats on this one glad you figured it out
Iorana Haraharaini
PostPosted: September 19th, 2011, 5:26
Nick, out of curiosity, what was the problem with the drive after all?
PostPosted: October 8th, 2012, 16:09
It seems I have exact same issue as Nick. Heads are OK, NVRAM reads fine, FW mods can not be read, NVRAM from SA can not be read. Drive does not ID. Doesn't click, spins up and stays spinning and sounds normal.
I AM using HD Doctor however.
Nick, care to give a hint as to what you found?
PostPosted: October 8th, 2012, 18:49
What is the history on the drive?
Are you using the original heads to read the firmware?
PostPosted: October 8th, 2012, 22:06
Thanks for replying--I've been working on this drive for 3 weeks.
Spins when powered up, but no 'initialization' sound from heads.
Comes to Ready, does not Load from HDD (goes to error state)
Read NVRAM--succeed
Read NVRAM from SA--FAIL
Read RAM--succeed
Read ROM--succeed
Heads click when trying to read first F/W Module: RSVD (and fails to read, of course)
Read of other modules fail without head noise, or if I try to to read any individual module. Also, goes into 'error' state after/while trying to read any module (and fails to read). Have to power off/on to bring to 'ready' again.
All above is same with donor PCB. With patient PCB attached to donor drive and appropriate ICs swapped, donor drive works perfectly, so PCB is not the issue.
Have tried programming with donor NVRAM.
Same symptoms with head swap.
PostPosted: October 8th, 2012, 22:23
As far as the history, it wasn't dropped or jarred--just received it that way in a laptop from a customer.
PostPosted: October 8th, 2012, 22:35
Do the donor heads still work after placing them back on the donor?
PostPosted: October 8th, 2012, 23:33
Yes, head stack from donor to patient then back to donor--donor drive still works, as in Nick_CT's original post above.
PostPosted: October 8th, 2012, 23:50
Seems like media damage in the SA.
PostPosted: October 9th, 2012, 2:55
This was a long time ago..... If my memory serves me correctly it required a compatible donor PCB with NVRAM written to it.
Users browsing this forum: No registered users and 104 guests
