 Post subject: Hitachi works only on Thinkcenter
PostPosted: September 17th, 2011, 0:43
I have got a strange hitachi desktop hard disk for repair. If connected to a particular Thinkcenter it works fine ,however if aconnected to any other system it shows 0mb.Even Hitachi DFT shows it 0mb. Is there any way to remove this limitations?
 Post subject: Re: Hitachi works only on Thinkcenter
PostPosted: September 17th, 2011, 17:25
And have you checked it's SA, or have you checked any type of encription?
PostPosted: September 18th, 2011, 7:08
Hi Thanks for lead
Disk is not encrypted with ATA passwword since it works fine with thinkcenter wothout putting password ,also it does not show capacity means this could be f/w issue. I haven't checked SA.
PostPosted: September 18th, 2011, 15:57
Does the thinkcenter have TPM enabled?
Data Recovery Ireland
PostPosted: September 18th, 2011, 17:23
Wait you say it is working on a thinkcenter but not on any other system. Now I read that it will still shows 0 capacity. So I am confussed on this one. Does it work on thikcenter or does it not. Does it show cqpacity or does it not? If you have this problem then you need a tool that can read your SA A and SA C and know how to fix the SA on this to get back your HDD to work right again.
Iorana Haraharaini
PostPosted: September 19th, 2011, 2:00
Thanks all for help,
this disk works fine on thinkcenter like normal disk ,however it shows 0mb if connected to any other pc.
I suspect it could have been locked by some hardware based cards like recovery card. I will take some pro help to clear SA as suggested by poehere
PostPosted: September 19th, 2011, 2:07
Seems that this PC-Guard is some how HW Solution to protect contents change
i`ve used such Software similar idea but with more network control options
called DeepFreeze if am not mistaking here
inside this solution, you should i think Unlock it through the HW, then take it back anywhere else
may or may not work
try it
PostPosted: September 19th, 2011, 13:29
Hi
I am wondering how Can a hardware lock hard disk in such a way that even manufacturer tool cannot detect right paramerters? I am sure any hardware card will not be writting anything on disk firmware ,rather no one can access or modify firmware.
isn't it a challeneging question
PostPosted: September 20th, 2011, 0:55
TaskManager wrote:
Hi
as an example to this the Smartware WD
in addition
i`ve seen many protection methods for privacy, and this is one of them and many more
there are many HW cards that locks the hdd in startup (power-on) and without unlocking them through it u will end up on Huge Circle
good luck
Users browsing this forum: No registered users and 124 guests
