 Post subject: Hardrive Failure Help
PostPosted: September 18th, 2011, 11:05
Hi
My Toshiba C650 Hardrive Was making some noises over the last few days and now its not loading the OS or anything. I have an old laptop an Advent 7201 It has a 160gb hardrive thats WD Scorpio Blue and the Toshiba laptop has a Toshiba Disk Drive MK2565GSX.
Is there any way i could swap the harddrives round because when i put the Advent HD in the Toshiba it comes back with a blue screen but its only on for a few seconds and cant read what it says.
Do you think the Advent HD will work in my Toshiba somehow ?
 Post subject: Re: Hardrive Failure Help
PostPosted: September 18th, 2011, 12:06
That blue screen might be some OS drive issue, as probably the OS and hardware are quite different between both PC's.
What's the OS in both PC's?
PostPosted: September 18th, 2011, 12:20
Hi
Toshiba - Windows 7 Advent - Xp ;L
So if i wipe the Advent one put it in the Toshiba and reinstall OS woulds that work ?
PostPosted: September 18th, 2011, 12:49
The bluescreen is probably because of hardware-driver missmatch so it's worth backing up your data and giving it a go at a fresh install
PostPosted: September 18th, 2011, 12:58
Hi
So how do i wipe my advent hardrive so that i can install a fresh OS
How do i wipe a harddrive ?
PostPosted: September 18th, 2011, 13:25
1st, back up your data if any is important.
2nd, if you want to install new OS, then there is no need to wipe the drive as the newly installed OS will write over the old data.
If you insist on wiping the drive, then you can do a full format with Win 7 and it will wipe all residual data. If you prefer to wipe prior to new OS installation, then you can look into free utilities such as MHDD (erase command). You can find MHDD for download in the software section of hddguru.
PostPosted: September 18th, 2011, 13:32
Hi
I tried that but on my Toshiba running 7 well was, XP started up but then it came up with a blue screen again so what going on ?
PostPosted: September 18th, 2011, 13:39
Hardware and driver compatibility is the problem. All previous posters have been telling you this.
I suggested advice with regard to wipping.
Hi
Ok so if i folow the wiping post it should work after wiped ?
PostPosted: September 19th, 2011, 3:46
It should work, yes.
Be sure to make the laptop boot from the Windows 7 DVD if you want to format the harddrive and do a fresh operating system install.
This is a screenshot from the Windows 7 install procedure. It's pretty self explanatory
Good luck!
Users browsing this forum: Google [Bot] and 280 guests
