 Post subject: Samsung HM250HI
PostPosted: September 26th, 2011, 8:26
Patient is clicking, I changed heads, but the patient is still clicking. (The heads are now back in donor which is functioning just fine, so the swapping should have been ok.) Any hints?
 Post subject: Re: Samsung HM250HI
PostPosted: September 26th, 2011, 8:47
same model for both hdd i suppose, so may the hdd can't read sa and init itself.
did u try hot-swap to read fw modules?
PostPosted: September 26th, 2011, 9:00
Yes, same model both of them.
Hot-swap did not work out.
PostPosted: September 26th, 2011, 12:57
Doesn't work, in fact :mrgreen:
PostPosted: September 26th, 2011, 15:54
What doesn't work? :roll:
PostPosted: September 27th, 2011, 2:07
Could you be more precise, please?
PostPosted: September 27th, 2011, 2:22
means hotswap
PostPosted: September 27th, 2011, 3:34
einstein9 wrote:
means hotswap
Obviously. Is the meaning of the comment that hotswap does not work with these drives at all?
PostPosted: September 27th, 2011, 9:54
It does, if you do it right ;-)
PostPosted: September 27th, 2011, 10:32
THAT'S the problem. Otherwise, there's plan B (but this require something extra....)
Users browsing this forum: No registered users and 273 guests
