Hey guys
First time post. I had one of my laptop hard drives fail in the past few days (ugh...half a glass of wine in Italy right onto the keyboard). I was able to save pretty much everything on the laptop, but now I realized the second hard drive doesn't work whatsoever.
Its not visible in BIOs in either position, but the first HDD is visible in both ports. I suspect the PCB is damaged from some weird coloring on the back of the PCB. I can't pull it completely off right now because I'm away from home. I have attempted to dry it, but I'll still need to attempt to clean off the PCD on the other side when I get the proper tools.
Luckily my laptop has two HDDs! I have uploaded the photos, and I'm wondering if its possible to use the PCB from one right onto the other because they are almost identical. Would I need to steal any chips at all?
File comment: Good HD on the left, bad on the right
Thanks before hand guys!
